Go to Post Engineers are not eligible to join NEMO, but that's OK! For us, there is an ad-hoc disorganization, notionally dubbed EMO. Meetings have no agenda and are called at random, usually in the evenings following long days at FIRST events. - Richard Wallace [more]
Unread 22-05-2006, 19:43
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Interupts on Vex in MPLab
For one of my classes i am attempting to further my understanding of interupts by using them on the Vex system. I know how to initialize them for the FRC controller. I am wondering if it is the same code to initialize them as low priority interupts on the Vex controller. Also does anyone know of sample code (not easyC) that would show how to initialize them?
Unread 24-05-2006, 08:32
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
Re: Interupts on Vex in MPLab
what interrupt did you want to use? timer0 is used already. the guys at vexlabs suggest not using them at all to avoid glitches in the pwm and the communications with the master controller. but, yeah, however you do it on the frc controller should work. i understand it's the same micro-controller as you guys used in '05.
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Vex Easyc vs Mplab Joohoo Programming 17 27-01-2006 08:22
Interupts on the Pic18 Andrew Schreiber Programming 10 21-01-2006 22:54
Interupts? Validius Programming 6 11-01-2006 18:29
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
