Go to Post Overall, I thought FIRST did a great job with the rules this year - very simple and very clear for the most part. However, something is always going to fall through the cracks (and I don't mean that in a bad way - people need to know that it's practically impossible to do something perfectly). - Chris Hibner [more]
Unread 28-05-2006, 03:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Getting Windows XP off of domains
I recently saved a computer from the trash dumpster. Remarkably it still worked and had XP Pro installed on the hard drive. Here's the only problem. It is set up on domains. So, instead of the normal XP login screen where you select the user, you get a screen telling you to press Ctrl-Alt-Delete and once you do you get network domain login (like this).
I have managed to reset the admin password but only for local login, so that does me no good until I can log in like usual.
So, can someone please help me out to remove the domain login? I know there's got to be a way to do it, whether it be through some sort of Linux LiveCD or command prompt or whatever. I've searched quite a bit and tried a few things but with no luck.
Please help me make this trash into treasure. Thanks.
Windows vista!!! [527]phil General Forum 27 25-07-2005 17:01
Getting off CMT pulleys Adam Y. Technical Discussion 4 30-01-2004 07:08
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
Windows ME robot180 Chit-Chat 11 07-07-2003 00:21
Threads getting off topic Mike Soukup CD Forum Support 29 20-08-2001 04:08
