Go to Post Karthik was never one to shy away from the spotlight (often to the chagrin of anyone within sight or earshot of him :p ). - Travis Hoffman [more]
Unread 29-05-2006, 21:27
alysume alysume is offline
FRC #0192
alysume is an unknown quantity at this point
Hex vs. Key
Our team is planning our drivetrain for next year, and we are considering using hex shafts instead of a key, as we have done in previous years. What are the pros and cons of each? I've heard that a hex broach costs quite a bit of money, but that's about all I've heard. Also, how do hex shafts work with e-clips?
A couple more hex related questions:
-When we buy say 3/8" hex stock, is 3/8" the diameter of the incircle or the circumcircle?
-If we buy 3/8" hex stock, I'm assuming we would use a 3/8" hex broach? Would we drill a 3/8" hole, then broach it, or drill some smaller hole?
-We only have a manual lathe. If we wanted to turn down the ends of the hex shaft so that they fit into bearings, is the interrupted cut hard to deal with?
Thanks a lot!
Hex Broach Options? Andrew Blair Technical Discussion 31 25-08-2006 21:12
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
Hex file downloads Ryan M. Control System 2 29-10-2005 19:50
HEX CRAWLER... Arefin Bari Chit-Chat 3 01-05-2004 00:12
Hex key sizes archiver 2001 3 24-06-2002 01:21
