Go to Post Please ask yourself..."If my robot is on fire and the pneumatics are randomly activating, is my main breaker someplace that I want to put MY hand?" - Jaxom [more]
Unread 31-05-2006, 07:16
tacman1123 tacman1123 is offline
AKA: Tac Tacelosky
FRC #1900
tacman1123 is an unknown quantity at this point
Send a message via AIM to tacman1123
PC Control of Vex processor
The sensors and interrupts of the Vex controller can be read pretty easily by downloading the "On Line" code and opening up a terminal emulator, setting the baud rate to 115200 and reading from the appropriate COM port. The Online code also lets you set the motors by moving a slider. Can anyone tell me how that's done? Obviously, a string of some sort is being written. Does anyone know the protocol for that?
Thanks!
Tac
Unread 06-06-2006, 10:47
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: PC Control of Vex processor
It would probably be best to connect to serial ports together and use hyper terminal to "sniff" the port. Then you can emulate the online window. We can't release that data for support reasons.
Off board processor? Joohoo Programming 11 22-05-2006 22:13
Processor Speed Updates NASAbound1636 Programming 2 02-03-2006 16:56
Processor Corporat Technical Discussion 3 13-01-2006 21:10
Member of multiple (FRC, FLL, VEX) teams in profile/user control panel? Elgin Clock CD Forum Support 3 03-12-2005 20:41
Parallel Processor rohandalvi Kit & Additional Hardware 25 27-10-2004 20:21
