Go to Post Genius is one percent inspiration and 99 percent perspiration, which is why engineers sometimes smell really bad. - Koko Ed [more]
Unread 01-06-2006, 13:24
jcsymmes jcsymmes is offline
jcsymmes is an unknown quantity at this point
Disabling Vex compiling errors
I am working on a Vex Project and getting a
"Type qualifer mismatch in assignment"
I have modifed the Userapi to produce a "system "command.
Doing research i have discovered (though won't bet my robots on) that this error doesn't actually mean anything, just that its expecting a 24 bit argument instead of a 16 bit argument in the line. which goes
System ("c:/White.wmv");
is there any good way of disabling this violationg so i can send my robot to its invetiable world conquest before the homecomming dance?
Thanks,
Scott
P.S if there was code that didn't make the error at all that whould work to.
Unread 01-06-2006, 14:13
koenig3456 koenig3456 is offline
Programming Coach
None #0681 (EARTH Squad)
Team Role: Coach
koenig3456 is an unknown quantity at this point
Re: Disabling Vex compiling errors
Thanks,
Scott
You can disable individual warning messages with the -nw switch. In this situation it would be -nw=2066
Unread 03-06-2006, 01:54
Thank you...
but at the risk of sounding stupid how do i do this?
Do i have to buy a special version of the compiler to turn off these messages?
Thanks agian,
Scott
Disabling the Radio Control Guy_E FIRST Tech Challenge 8 06-03-2006 14:57
Disabling the robot in autonomous? IMDWalrus Programming 10 18-01-2005 16:52
disabling a button gomez6760 Programming 1 12-08-2004 11:54
Disabling Autonomous Yan Wang Rules/Strategy 12 19-04-2003 19:06
Disabling drill transmission clutch Charlie B Motors 2 31-01-2003 10:02
