Go to Post How do you earn yourself 500 PM's, 200 e-mails, 100 replies to a post, and an instant 5 to 6 bars in rep? If your name is Grant Imahara, make yourself known to the Chief Delphi community. - Andy Grady [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 01-06-2006, 13:25
tacman1123 tacman1123 is offline
AKA: Tac Tacelosky
FRC #1900
tacman1123 is an unknown quantity at this point
Send a message via AIM to tacman1123
Angle Sensor for Vex
I'm looking for a rotation sensor for the Vex, an angle sensor. I have the optical shaft encoder, but I see that it doesn't measure the direction that the shaft is rotating, so it's impossible to use it to calculate the angle.
The new Mindstorm NXT kit will have angle measurements (to 1%) built into their servo motors, something which I think will increase the precision of Mindstorm bots significantly.
I've also played around with the idea of using the optical shaft encoder and some other mechanism for seeing which direction an axle is turning, but can't come up with anything that immediately responds to a change in direction. An angle sensor is really what I'm looking for.
Thx,
Tac
Vex Ultrasonic Sensor not responding SomeoneKnows Programming 6 18-12-2007 16:48
Vex line follower sensor kit program jbill30 Programming 5 12-05-2006 14:43
Vex Sensor Sample Code nonother FIRST Tech Challenge 2 08-05-2006 16:49
VEX Ultrasonic Sensor delay P1h3r1e3d13 Programming 4 28-03-2006 13:45
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
