Go to Post I am a 2-3 year competition veteran, and a new member at chief delphi, and everyone here seems to be as nice as they are at the competition. Very gracious, you might say. - Ian S. [more]
Unread 06-06-2006, 23:54
Gene Gene is offline
Gene is an unknown quantity at this point
Robot having internal heat problem
Does anyone know of an easy way to reduce the internal temperature of a small robot - other than heat sinks and fans?
It's a small robot my son assembled and is operated by a small battery... so some of the more sophisticated energy consuming techniques won't work.
Thanking everyone in advance.
Gene
Unread 07-06-2006, 00:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Robot having internal heat problem
The two methods you mentioned are the most conventional. Other methods are dry ice and "canned air" turned upside down and sprayed. Be careful with the two of these things though.
Unread 07-06-2006, 01:21
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Gene
Bigger heatsinks (maybe even a large brick of copper) & more fans, mainly, if you can get a proper air flow going over the hot spots then that'll pretty much fix the problem. If you can't power a fan, I suppose you could try using copper heatpipes to channel heat to a heatsink outside of the robot?
Dry ice might work. It runs out, though. And putting dry ice or turning a duster can upside down and spraying hot spots can create thermal shock, which is generally bad.
Hope this helps.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 07-06-2006, 02:13
Thanks for the information - But I should have mentioned
the little guy loves to run this thing in the middle of the afternoon - plus the exterior of the can is also used to mount the gearhead motors. The frame, if we can call it that, is a large retangular can from a surplus store.
Since he and his buddies are running this thing for hours in 100 degree + temperatures, short term solutions won't work. Additionally, everything is encased in that oversized ammo can with two exterior vents. So he doesn't really get an "A" for applications in innovative thermal management.
Anyway, I had considered heat pipe and cold plate for the controller and receiver . . . but being only a ME I can't come up with something that will keep the encased electronics cool when the ambient temperature is over 100 F without using a small generator to provided the needed power. Then suddenly his little automated ammo can becomes a big engineering project.
I am honestly stumped.
Unread 07-06-2006, 04:07
24 Hours of LeMons?
Re: Thanks for the information - But I should have mentioned
Paint it white, the olive drab ammo canister probably absorbs quite a lot of heat from the sun. Additionally, you can channel the heatpipes to the ammo can so that the heat spreads throughout the metal shell (I'm assuming it's metal, since I've never seen a plastic ammo box). 100*F for electronics isn't really bad for electronics, now if it were 100*C...
Unread 07-06-2006, 07:20
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
why does it need to be enclosed in a can?
Drilling ventilation holes would work wonders.
Unread 07-06-2006, 07:31
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I like the drilling holes idea but it takes away from the asthetic value of the the ammo can. You can add fins (painted to match) to the outside of the can so that airflow will cool the exterior, then mount the electronics (the hot bits) on the interior of the can.
Some kind of scoop intake on the bottom would be out of sight and vent holes on the top would allow convection cooling to remove some of the internal heat as well.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 07-06-2006, 09:08
Originally Posted by Al Skierkiewicz
I like the drilling holes idea but it takes away from the asthetic value of the the ammo can. ...
OK then, bullet holes would work too :^)
BTW, what is it thats producing the heat? the motors or the electronics?
most small hobbie motors have built in blowers. If they dont get fresh air for cooling it defeats the purpose.
If its the electronics, are you sure you really have a problem? If it runs for 2 hours its pretty much heat-soaked to steady state. If its still running at that temp it might be ok.
Most electronics will operate at 95°C without failing (too hot to touch).
Unread 07-06-2006, 10:20
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Why not combine your ideas? An Ammo can riddled with bullet holes seems to fit the theme. You get "aesthetics" and function.
If you are not the shooting type, but still would like it done, look me up. I'm sure we could arrange something.
All "funnin'" aside, can you post a picture of your son's project, it might help us help you find a solution.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 07-06-2006, 16:17
Good question Ken. The motors venting heat into the container; the radiant energy coming off the “desert” floor (which can go up to 120 F.) and the direct sunlight. Remember, this is the place where you can’t go barefooted in the summer because you’ll burn the bottom of your feet (second degree burns!!). Moral of the story - If you live in the southwest – live near the ocean or in the mountains.
Anyway, if he insulates his ammo-bot, he protects it from the direct sunlight. If he draws in outside air, he pulls in the hot air radiating off the ground. If he insulates the entire unit, he protects it from the radiant energy – but bringing in outside air is a no-no because the outside air is merely heats the electronics.
He also asked how they’re keep the electronics cool in Iraq. Needless to say, he didn’t like the answer. But I assured him, I had found a great web-site used by some of the brightest minds in the world and since I was at a loss (short of redesigning the ammo-bot) . . . . the forum is his last and only hope.
You see how much faith I have in you guys!!
Unread 07-06-2006, 16:29
Team Role: Teacher
I don't know what size your motors are but if they are standard hobby RC car size you could try something like this with a small electric pump and tank. Do you have a picture of this robot?
EDIT: Actually, isn't there a way to make a fluid flow through a small cooling system just by using the heat (no pump required)? I think I've heard of that before, but I don't remember the details.
Unread 07-06-2006, 16:50
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Unfortunately, that'll only get it down to ambient temperature unless you use an active cooling method. For that, you need some sort of refrigeration, most units are much too heavy/power hungry, the only thing that I can think of that could do it is a Peltier junction. These are nifty little ceramic (I think) blocks that get hot on one side, cold on the other when you run current through them. Then you have to worry about condensation. Peltiers could instead be used with fans to help reduce the temperature below ambient. I don't know where you could get one though, but they used to be popular with the extreme case-mod/water-cooling crowd so there probably is a place to acquire them. Most will probably be in the 12VDC area, but power consumption is pretty low, (if I remember correctly) 10 NiCd AAAs could probably power it and the robot, NiMHs would be even better. (less toxic) The Robot Marketplace has customizable battery packs you could use.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 07-06-2006, 19:14
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Ooohh...Peltier's...those are cool. I might just suggest this little baby- http://www.electronickits.com/kit/co...tier/ck500.htm
You seem very intent on cooling the air, not just introducing it, so this in a sealed metal box would work quite nicely. Otherwise, just use a plain fan and some bullet holes as Bilbo said.
But I have a question: What kind of kid goes outside in 100 degree temperatures to play with a robot instead of slugging around inside watching TV? Sounds more like some crazed ME to me... ;-)
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 07-06-2006, 16:51
Unsung FIRST Hero
Rookie Year: 1996
Remember that no matter how hot the surrounding air is, it is still cooler than the dead air inside the box. If you circulate the air through the box it will take the internal temp down to the ambient. Without a cooling system, that is as good as you can get.
Al
WB9UVJ
www.wildstang.org
  #15   Spotlight this post!
Unread 07-06-2006, 17:08
Im not aware of any special cooling being used on electronics in the desert in Iraq.
Motors can get very hot with no problems. Most commercial electronic devices are rated up to 95C (not F, C).
The fact that its 100F in Arizona is no big deal. How hot do you think it gets under the hood of your car in the summer? How about inside your car after its sat in the sun all day? CD player still works just fine pumping out 500W inside a car that is hot enough to kill a dog.
Ambient air should be all you need, even in the desert - you just need to open the case a little and let the outside air in.
Is anyone else having this problem hpman247 Programming 10 27-11-2008 02:57
If you are having a problem with one of the members from this site what do you do ? team66t-money General Forum 1 10-02-2005 22:16
If you are having a problem with one of the members from this site what do you do ? team66t-money Electrical 0 10-02-2005 22:06
Having a little problem with the camera... capenga Technical Discussion 3 21-01-2005 10:54
