#16
Re: Robot having internal heat problem
iRobot also warns military end-users of potential heat related problems associated with desert operation. Aircraft avionics in addition to the weapon control systems are equipped with some very expensive cooling devices to include tubes, plates AND Peltiers. Added: Here is a overview of Peltiers: http://www.dansdata.com/peltprac.htm The operative phrase is high amps. As he mentions, the efficiency is increased as the load is increased. For the small ammo-bot, I think they may be the kiss-of-death because of battery requirements. But then, I'm only a ME not a EE. Last edited by Gene : 07-06-2006 at 19:05. |
#17
You seem very intent on cooling the air, not just introducing it, so this in a sealed metal box would work quite nicely. Otherwise, just use a plain fan and some bullet holes as Bilbo said. But I have a question: What kind of kid goes outside in 100 degree temperatures to play with a robot instead of slugging around inside watching TV? Sounds more like some crazed ME to me... ;-) |
#18
I'm guilty. He and his friends were talking about science projects, the news on TV (Iraq) and neat stuff like iRobot's little devices. So I thought a little robot would be a wonderful learning experience. . . and - well . . . . . it has been. He rarely watches TV. |
#19
Y'know, speaking of spending time inside, couldn't he drive the robot inside?
#20
First, I thought MEs were all about heat transfer. I know I had to learn entirely too much about it in college.
At any rate, I'll add to the chorus. I really think ambient air is your best bet, since anything else requires expending relatively large amounts of (electrical) work in order to cool below ambient. Simple thermodynamics and all that. Thinking about it, you could just make a rechargable cooling unit, however. Just something you put a piece of dry ice in and it provides enough cooling to last for a few hours. If we could get an estimate on how much current the whole ammo-bot draws we can figure out how much dry ice you'd need. In fact, an estimate of the power draw would be useful for figuring out any cooling solution. So... basically, what size batteries are we talking about, and how quickly do they get drained? |
#21
whats wrong with wet ice? (besides being free from the ice cube maker? :^)
#22
or put ice cubes in a small freezer bag
#24
Thanks for the valuable input guys!!
I’d like to thank:
Al Skierkiewicz Andrew Blair billbo911 Billfred KenWittlief Kevin Sevcik lukevanoort NoodleKnight sanddrag for all the help, thoughts and concerns provided by a great bunch of guys. I let the “little fellow” review the thread, then we had a Q and A. One of the more pronounced issues you guys helped him learn and perhaps one of life’s most important lessons, is that everything has trade-offs. And just as important . . . design and build for an application. His solution, redesign. Use different more nonconductive outer materials, good insulation, incorporate a larger power source, draw external air until it reaches a predetermined temperature, then to use Peltiers with thermocouples to avoid a constant power drain. But the big deal, at least to me, is the team concept and importance of listening to everyone’s input . . . because moving “in the opposite direction” may be the wisest decision. |
#25
Anytime, just ask. Good luck! 73's
| Is anyone else having this problem | hpman247 | Programming | 10 | 27-11-2008 02:57 |
| If you are having a problem with one of the members from this site what do you do ? | team66t-money | General Forum | 1 | 10-02-2005 22:16 |
| If you are having a problem with one of the members from this site what do you do ? | team66t-money | Electrical | 0 | 10-02-2005 22:06 |
| Having a little problem with the camera... | capenga | Technical Discussion | 3 | 21-01-2005 10:54 |
