Go to Post "In theory it will work" - Fuller [more]
Unread 16-06-2006, 18:35
zafara17 zafara17 is offline
FRC #0639
zafara17 is an unknown quantity at this point
Vex Programming Help!
Hi. I am programming my vex robot and was wondering if the remote control stick could be configured so it is a tank drive, upwards and downwards, and each left and right movement of each joystick could be set to trigger a few motors. I was wondering if this is possible with regular C programming and what the code looks like.
If this is not possible, can any of the other buttons on the vex remote control to be set to trigger motors?
Thank you.
Unread 18-06-2006, 13:48
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Vex Programming Help!
If you are using MPLab just have something like this:
pwm01 = PWM_in2; // Left drive = left joystick up/down
pwm02 = PWM_in3; // Right Drive = right joystick up/down
//for one motor on each joystick left/right
pwm03 = PWM_in1; //extra motor 1 = Left joystick left/right
pwm04 = PWM_in4; //extra motor 2 = right joystick left/right
//for multiple motors on each joystick left/right
pwm03 = pwm04 = ... = PWM_in1;
pwm05 = pwm10 = ... = PWM_in4;
I don't know EasyC , but you should be able to do something similar.
Eric Haskins KC9JVH
Unread 18-06-2006, 14:12
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Originally Posted by Kyle Love
Linked is an aray of vex help items, some of the stuff may be found to be useful.
Since the above link will expire in a few hours, use this link if the above link does not work. (You will need to hit "Search Now").
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
VEX programming Gene F Programming 14 08-08-2006 22:21
Vex Programming help! davelu Programming 4 23-12-2005 22:03
Vex Programming Module Vex FIRST Tech Challenge 3 30-08-2005 21:27
Vex like programming? Morenoh149 Programming 2 09-07-2005 22:32
Vex Programming foobert FIRST Tech Challenge 3 24-06-2005 01:09
