Sharing motor(s) tranmissions in Swerve drive
For some background on our team's first ever summer prototype work read this thread.
What I am posting here is a request for what you think would be the pros and cons of having a single motor and transmission per side of a crab-steer drive system. (What is a side in a swerve system?) Consider having a single transmission with one or two motors being shared with two modules per side. Front/Rear or Left/Right. Add to that the concept of also steering modules in the same pairs. I'd like to reference a white paper by team 79 Krunch for info on steering options in swerve drives. Anyhow, Post your thoughts ![]() |
Re: Sharing motor(s) tranmissions in Swerve drive
With regard to driving them together, it's feasible, but be aware that you'll limit yourself a little bit in the area of complex motions (because you can't get all 4 wheels spinning at different speeds). This probably won't be too big a deal, though, because it's difficult to control that sort of motion by hand. In autonomous mode, it might limit your options a little, but you should be able to work around it.
Also, if you steer them together, you're limiting yourself (under most circumstances) to either a lot of sliding, or to translations only. As long as you're happy with a skid-steer component to some of your turns, this is quite possible. In fact, most robots forego the ability to steer modules independently, because they'd rather use the motors elsewhere, and don't really need fancy rotational moves (like orbiting an object while revolving around the robot's own axis). I'm trying to remember if 47's 2002 robot had 4 independently-driven and independently-steered modules; I think that it did, and that would make it one of the very few with that capability. Last edited by Tristan Lall : 22-06-2006 at 19:49. |
Last edited by Tristan Lall : 22-06-2006 at 21:28. Reason: I was going to post some pictures, but realized that I wasn't sure about the robots that I'd identified.... |
[edit] pics can be found here and here [/edit] Last edited by RogerR : 22-06-2006 at 23:28. |
Thanks for the compliments guys.
Our team used "Swerve" drive systems for several years. Some independant (all 4 wheels) configurations and a - Four Wheel configuration moved by a single motor. All had their good and bad points. The nature of the game in recent years has made swerve drives to be shelved in place of powererful fast systems that can climb. Due to resources required both mechanical and physical the need for swerve has been very low as it would impact the game very little. I see an opening for FIRST to have a game that will require the felexability of a swerve drive system. Swerve is many times confused with a steerable chassis (like a car). |
Incidentally, 47's 2001 and 67's 2005 designs drive all of their points of contact; 47's 2000 and 1114's 2005 drive only two points of contact, and leave the other two as casters—this retains maneouverability, but sacrifices maximum pushing force (because the total normal force on the driven wheels is lower, and they therefore exert less friction). |
| pic: Coaxial Swerve drive, lightened. | CraigHickman | Extra Discussion | 19 | 22-06-2006 15:00 |
| Swerve Drive Whitepapers/Info | Ryan F. | Kit & Additional Hardware | 1 | 20-10-2005 00:51 |
| Swerve Drive on a Jeep | Karthik | Math and Science | 3 | 01-02-2005 17:50 |
| pic: Lego Swerve Drive | CD47-Bot | Robot Showcase | 14 | 26-06-2003 16:19 |
| Swerve Drive | Jeff Waegelin | Technical Discussion | 14 | 17-09-2001 08:06 |
