Outdoor Autonomous Vehicles
I have some Traxxas Rustler Skeletons in my basement that I eventually wanted to make into an autonomous outdoor vehicle. On of the things I have been having difficulty figuring out if what to do about how I tell it where to go. I am guessing the only way to do it is to integrate a GPS into it. If so what kinda of GPS can one get for a project like this.
Re: Outdoor Autonomous Vehicles
If you want a GPS module this module has great reception and is very easy to interface with. You will just have to write some code that will parse the NMEA stream to get the data you want.
You can also set up boundaries, for example if you don't want the robot to leave your backyard. This could be as simple as a buried wire with low-power radio frequencies on it (kind of like those invisible fence thingies for pets), or a simple colored border (think a piece of tape), to an infra-red light beam that cannot be crossed (like a Roomba virtual wall).
Better still would be to give your outdoor vehicle a purpose. Here in the northeast, picking up sticks or leaves from the trees is one choice. Maybe yours can harass the local fauna, or act as a watch-bot. For cross-country navigation, you need some kind of rangefinding, and a vision system. Vision seeks the clearest path, rangefinding determines if the camers is seeing a path or just the scenery over the edge of a cliff... No matter what, put two safety shut-offs on the bot: One big red button right on it where it can easily be reached, and another via Radio. Just in case something goes wrong, anyone who is about to be run down by it can hit the red button instead. Sounds cool, approach the problem in stages instead of as one huge project. Get a rolliong chassis first, then start adding more and more autonomous features. Don |
Now, don't get me wrong, I'd still have something in such a project besides flipping the truck on its body (although that would stop a Rustler every time)--perhaps a portion of the wire could route through the roof of the body with a quick-disconnect battery connector attached? I'll be watching this thread closely--my Rusty is a bit...well, rusty. Last edited by Billfred : 01-07-2006 at 11:01. |
Be aware that when you start adding weight to an R/C car, you have to start making adjustments and upgrades to suspension, motor, gearing, speed control etc. R/C cars are not made to carry a lot of weight.
There is a fine line between using a R/C car saving you development time and money and the modifications and hassle of the premade stuff slowing you down. Just keep that in mind. I've been involved in a few R/C car to robot projects and in the end we've always scrapped the chassis in favor of custom stuff. Usually, the only usefully thing at the end of the day are transmissions and suspension. Weight is you're absolute enemy if you don't want to do any hardware modification. Good luck! -Andy A. |
If you gonna be adding a GPS module you are gonna also have to add the processor and possibly more batteries. If you are planning to go any further than that the speed of the car with most likely be decreased. |
So my senior design project was a drive-by-wire ATV with a semi-autonomous mode built in. We used an Innovation FIRST MiniRC (also known as the 2004 Edu RC) with a Garmin 18-5hz GPS receiver. The receiver pipes data out to the MiniRC via the TTL port. We attached a 900Mhz serial radio modem out of the "program" RS-232 port on the MiniRC to transmit data back to a laptop. The laptop has a map of the area that can be clicked on and the ATV would drive to the location. I'm not saying it is the best it could be, but you can check out what we did on our website at http://mem15.no-ip.org . Click on the Documents link on the left and you will be able to find (in one form or another) all of our documentation and how to recreate it.
what do you mean you hook up to the GPS's TTL port? Is it a TTL serial port?
#10
On the software side, we used code from Kevin Watson's FRC Code Repository as a base-line for our I/O functions. Both the RS-232 and TTL ports on the MiniRC can be used to input or output data. |
#11
Is the actual positioning data hard to interpret?
#12
Hmmm. Chainsaws, eh? Don |
#13
-Q |
#14
My first plan was to actually use a chainsaw, but it would have cost too much to make everything myself.
| pic: An outdoor Practice Area | JVGazeley | Extra Discussion | 8 | 30-03-2006 16:26 |
| I <3 Autonomous | Mike | General Forum | 3 | 26-04-2005 22:21 |
| Autonomous | danielkitchener | Rumor Mill | 3 | 03-01-2004 01:08 |
| autonomous..... | Arefin Bari | Rumor Mill | 30 | 19-12-2003 10:53 |
| Autonomous | Jestin Hashop | Rules/Strategy | 2 | 11-02-2003 19:24 |
