Go to Post If you always do what you’ve always done, you’ll always get what you’ve always gotten. - rourke [more]
Unread 01-07-2006, 17:54
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
pic: Vex fan powered :D
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 01-07-2006, 17:55
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: pic: Vex fan powered :D
How fast does it go?
Unread 01-07-2006, 18:03
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
How does it turn? You should put a servo on the super grippy wheel there and that would be really cool.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 01-07-2006, 19:13
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
it cant turn... this is a prototype. Next one will have an omni wheel with a flap on the back
Callsign: N6ARA
Unread 02-07-2006, 12:19
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Which ESC are you using to drive the fan motor, and what motor are you using?
I have an entirely different project that I will be using a similar ESC to run an old RC car motor on and was wondering how well that ESC is working.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 02-07-2006, 15:45
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Seeing how you are using something other than the wheels to drive this thing have you considered adding pontoons so it can drive on water?
Where's the fun if your limited to just land....
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 02-07-2006, 16:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
My best guess is that it's an Mtroniks. Perhaps the RV15 model?
EDIT: Whoa, no way. I just now read the picture description and it lists the ESC in there, and I totally guessed right. I guess I'm just WAY too into this stuff.
Unread 03-07-2006, 11:23
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Nice guess , Yes it's an Msonik RV15 ESC , It is supposedly a forward and reverse speed controller, but for some reason on the VEX set it doesn't go backwards. That is the sort of problem you get when you take something that isn't designed for the other and put them together.. but hey where is the fun in not experimenting things like that?
Callsign: N6ARA
Unread 03-07-2006, 12:23
billbo911's Avatar
I hope I can help here.
I did some research into small ESC's a couple months ago searching for one that would go from forward to reverse without going through a "breaking" mode first. I need it for a self balancing robot. What I found is that there are VERY FEW models out there that will do this. Most of the small units had some form of "intelligent breaking". The unit, while running in forward, would then proportionally turn on a "breaking" FET if the control was moved to reverse. Once the ESC sensed that the motor had stopped, and the control returned to neutral, it would then go into reverse if the control was again moved into the reverse position. So, if in fact, that is how the RV15 operates, you would have to be running forward, move the stick into reverse until the motor stopped. Return the stick to neutral then into reverse again for it to run the motor backward.
The other possibility is that the ESC needs to be "calibrated" for it to know how to operate based on the signal sent to it. Many of the smaller ESC do a "self calibration". When the ESC if first powered, it measures the PWM signal and "assumes that value to be neutral. Then it continues sampling the PWM and records the Maximum PWM it sees as "Full Forward". The sampling continues until it sees "Neutral" again and then it records the "minimum" PWM value it sees as "Full Reverse" until it sees "Neutral" again. It is now calibrated.
So, if the cycle it sees actually goes as follows: Neutral, Full Forward, Neutral, some forward value, Neutral, it is quite possibly not providing a reverse range because it never received a " Full Reverse" value. This is a guess so please verify by reading the details of the manual.
How would you correct this in Vex? Write the initialization code to output the correct range of values to the ESC during start-up.
Unread 03-07-2006, 18:28
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Wow, thanks for that I will try and read up on that. I would program it but the problem is I dont have the Programmers set.
Callsign: N6ARA
Camera not powered...? Total Meltdown Programming 7 14-01-2006 01:54
Pneumatic powered cannons. Ronald_raygun Pneumatics 10 06-12-2005 01:09
Air-powered motors Zing Rumor Mill 17 29-12-2003 14:19
Powered OI input EricS-Team180 Programming 7 28-09-2003 21:23
