Go to Post The toughest part about that Chairman's Award was the fact that someone was cutting onions in the stands near 558/on the field while it was being read out. At least that was the excuse I'm going to use ;) - esquared [more]
Unread 02-07-2006, 15:45
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Battery Voltage variable on EDU controller
I am trying to use the battery_voltage variable in user_routines.c but I get this error when trying to compile..
Error [1205] unknown member 'rc_analog01' in '__tag_167'
Am I missing something?
EDIT
After looking at 'ifi_default.h' i found this block of code..
Code:
  unsigned char oi_analog01, oi_analog02, oi_analog03, oi_analog04;  /*rxdata.oi_analog01*/
  unsigned char oi_analog05, oi_analog06, oi_analog07, oi_analog08;
  unsigned char oi_analog09, oi_analog10, oi_analog11, oi_analog12;
  unsigned char oi_analog13, oi_analog14, oi_analog15, oi_analog16;
  unsigned char rc_main_batt, rc_backup_batt;
So i decided to try rc_main_batt and rc_backup_batt...
If found that if you took rxdata.rc_main_batt and applied the formula "current voltage = battery_voltage * 0.038 + 0.05; " found at the bottom of 'ifi_aliases.h' you get a value of 650.. im running the the controller off a wall adapter putting out 6 volts to i think this is pretty acurate.
Here is the code if anyone is interested..
Code:
float current_voltage = 0;
float average_voltage = 0;
int voltage_count = 0;
int i = 0;
int i2 = 0;
void Process_Data_From_Master_uP(void)
	Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
	current_voltage = rxdata.rc_main_batt; 		// Store current voltage
	average_voltage += current_voltage;			// Add the current voltage to the average stack
	voltage_count++;							// Increase the average stack count
	if (voltage_count == 39)					// If the stack is 40
		average_voltage = (average_voltage / 40) * 0.038 + 0.05;	// Get the average and apply formula
		i = (int)average_voltage;									// Truncate decimals
		i2 = (int) ((average_voltage - i) * 1000);					// Subtract to get decimals only and then multiply by 1000
		printf("Average: %d.%03d \n",i,i2);							// Print the two together to make it look like a decimal
		average_voltage = 0;										// Reset the stack
		voltage_count = 0;											// Rest the counter
	Putdata(&txdata);             /* DO NOT CHANGE! */
Thanks to Mark McLeod for example on how to printf floats...
EDIT
I just tried using
current_voltage = rxdata.oi_analog01;
and i get averages of 4.7 so im not sure what to think now.. can anyone clarify as to what one it is and why i get an error when i try to use the 'battery_voltage' aliase... also i just realized that the battery_voltage aliase points to 'rxdata.rc_analog01' which i cant seem to even find anywhere..
Unread 02-07-2006, 20:14
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Battery Voltage variable on EDU controller
Are you using the EDU header files? For those two fields (rc_*_batt), I have "res01" and "res02".
In ifi_aliases.h (EDU version), it has this macro:
Code:
 *---------- Alias for Battery Voltage  -----------------------------------------
 * current voltage = battery_voltage * 0.038 + 0.05;
#define battery_voltage rxdata.rc_analog01
Also, I'm pretty sure the formula is known to be inaccurate.
Unread 02-07-2006, 23:05
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Yeah im sure im using the right header files... i got it off the ifi website three days ago from this URL http://www.ifirobotics.com/mini-rc-read-me.shtml
Has there been an update or something?
The 8.2 (or 8.3) Battery Voltage Bug eugenebrooks Programming 167 21-02-2008 20:05
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
Battery voltage Josh Siegel Programming 5 22-12-2003 10:15
Battery Voltage Neal Probert Programming 3 09-01-2003 10:18
