Go to Post It's one thing to post thoughts, guesses, opinions - that's all good ... However, it's [different] to make statements claiming first hand knowledge & facts without actually having first hand knowledge, facts, or accurate information. - Jason Morrella [more]
Unread 03-07-2006, 11:19
StargateFan StargateFan is offline
StargateFan is an unknown quantity at this point
Serial Port Help?
Hello Everyone,
I am a new Vex User this summer and I'm trying to setup my robot to communicate with my computer's serial port. I found and dowloaded the serial drivers posted by Kevin Watson. There was a HEX file already made so before I messed around with anything I downloaded that program to my robot. Now I can't download any other programs to my robot. The IFI loader gives me an error that says I should turn on the power to my robot or connect the serial cable, however both of these are true. Has anyone else had this problem? Can you tell me how to fix it so that I can program my robot again?
Thanks!
Unread 03-07-2006, 11:42
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: Serial Port Help?
Originally Posted by StargateFan
Hello Everyone,
Thanks!
Hm...I'd suggest simply checking to make sure that in IFI loader, make sure you have the right port number assigned. I've forgotten to check this many times before, and it's usually the problem I have when I get this error. It could be something as simple as that.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 03-07-2006, 12:06
It's not the serial port. I just checked. I also tried cycling the power on my robot. I even tried changing the battery just in case there was not enough power going to the robot. I still have the same problem.
Unread 03-07-2006, 13:15
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
These might be similar problems posted on the Vex Forum
http://www.vexlabs.com/forum/viewtopic.php?t=171
or
http://www.vexlabs.com/forum/viewtopic.php?t=3&start=15
Unread 03-07-2006, 13:39
When I try to verify the controller, it says "No Controller Found...".
Same thing when I try to download the master code.
Unread 03-07-2006, 13:49
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
Hmmm...you might want to try a master reset.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 03-07-2006, 14:07
All I do is twin.
AKA: elixir
Yeah, I was going to say that. Also, letting it sit for a few hours with no power running through it or anything might just be what it needs. *shrugs*
Unread 03-07-2006, 14:12
How do I do that?
Unread 03-07-2006, 15:31
Just Itinerant
Pushing the program button on the orange converter before you try connecting from the PC doesn't help?
Unread 03-07-2006, 15:35
Nope nothing happens when I press the orange button...
Unread 03-07-2006, 22:44
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I know its too late for this time , but you need to be careful which code you download to your microcontroller. Kevin Watson's serial driver hex was compiled for the PIC18F8722, while the vex controller uses the PIC18F8520.
These two processors are very different in that the 8722 has 4 flash memory banks and the 8520 has just one. This could cause the IFI bootloader to write only 25% of the code, or could possibly overwrite its own code during the programming process.
Also, I believe that the VEX controller's I2C packets that communicate between the User and Master (control) processor are constructed with different memory pointer offsets than on the FRC controller.
I'll be checking in on this thread now and then if anyone has questions.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 05-07-2006, 13:45
So does that mean I can't fix this at all?
Unread 05-07-2006, 14:06
Just Itinerant
I'd try the Vex forums at http://www.vexlabs.com/forum/ to see if they have experienced this problem and have a fix. You might have to return the controller to IFI for them to crack the case and re-flash the master code.
Any warning or indicator lights, if any, showing on the vex controller?
IFI_Loader Port Settings alright?
I've been busy ripping out walls and floors in my kitchen and had my laptop disk crash yesterday, so I didn't get back on this sooner.
Which Serial Port? crossedheart Programming 4 08-02-2006 11:35
serial port interface AMIRAM Programming 16 22-01-2006 21:16
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
No Serial Port Jeff Waegelin Programming 15 09-01-2003 22:29
