Go to Post No, but you have access to the most powerful machine tool of all; a telephone. We had zero machining sponsors, now we've probably had over 30 unique shops run parts for us; All we did was ask. - AdamHeard [more]
Unread 29-06-2006, 12:24
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
Smoking potentiometer
Sorry I'm posting this here, I didn't want to start a new thread for this question and I figure you guys will know the answer anyway.
Okay, I am having a problem with a smoking potentiometer. I hooked it up to a power supply to test controlling an LCD backlight with it. I hooked everything up okay and it worked for about half a minute, controlling the backlight brightness. Then it started smoking...
After checking everything, I hooked it up again to see if it still works (I used a multimeter to measure the output voltage). After a few spins and and about a minute it started smoking again.
Do you guys know why this is happening?
David
Unread 29-06-2006, 12:27
Zak698's Avatar
Zak698 Zak698 is offline
Jack The Robot King
AKA: Skittles
FRC #0698 (Microchip Microbots)
Zak698 has a spectacular aura aboutZak698 has a spectacular aura about
Send a message via AIM to Zak698
Re: Smoking potentiometer
David,
My respose would be that the lcd is drawing too much current for that pot, hook up your multimeter and see how much current it is drawing and then compair it to what the pot is rated at....
Unread 29-06-2006, 12:58
AKA: David Hillman
Originally Posted by Zak698
David,
That's exactly what I did. I hooked it up to a 5v current from a power supply, and to a multimeter. it looked like it was working fine for about a minute and then is started smoking again.
The pot says 500 ohm on it.
David
Unread 29-06-2006, 13:02
Zak698's Avatar
Jack The Robot King
AKA: Skittles
How many Amps is the pot rated for?
Unread 29-06-2006, 13:14
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
David
Does the pot have 500 ohms on it or just 500? 500 indicates a 50 ohm pot, 50 times 10^0. 50 ohms on a 5 volt supply is 100 ma or a power dissipation of 1/2 watt. Add to that the current you are supplying to the LCD and for most pots you have exceeded the power rating. Generally, once a pot has been stressed, it longer remains at the value it began with. Take your multimeter and set it to read resistance and place it across the pot to see what the value is now. Let us know shat you find.
Al
Al
WB9UVJ
www.wildstang.org
________________________
Unread 29-06-2006, 13:52
AKA: David Hillman
Al
The exact writing is " b500Ω".
And how exactly do I check the resistance?
This is the multimeter I have:
http://www.tenmars.com.tw/ezfiles/te...3_S_YF3503.jpg
Unread 29-06-2006, 21:25
Unsung FIRST Hero
Rookie Year: 1996
Dave,
You turn the switch to the lower left corner marked 2000, place a meter lead on each of the outer terminals on the pot and the meter should read 500 +/- 50 if things are OK. Then take one of the terminals and place it on the center terminal (leave the other on an outer terminal) and you should see the meter vary as you turn the shaft on the pot from zero to about 500. The meter should not show an open circuit during any point on the rotation. This indicates a failure of the pot internally. Is there any other markings on the pot? In your design, what does the pot feed?
Al
WB9UVJ
www.wildstang.org
