Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 08-07-2006, 19:30
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Where can I get a digital compass sensor?
I'm looking for a digital compass sensor. I have found this sensor, I also found this one.
The first one from Sparkfun looks hard to interface with and would be about 70% of my budget, and the second one isn't accurate enough for my project.
I was hoping to find a sensor for under $50 accurate to less then 1 - 2 degrees.
I have already spent many hours looking for this, but haven't found anything that's in my price range and is accurate enough.
Eric Haskins KC9JVH
Unread 08-07-2006, 19:37
divergentdave divergentdave is offline
FRC #1816 (Green Machine)
Rookie Year: 2007
divergentdave is a jewel in the roughdivergentdave is a jewel in the roughdivergentdave is a jewel in the rough
Send a message via AIM to divergentdave
Re: Where can I get a digital compass sensor?
Wouldn't this be foiled by the metal chassis of the bot, electronic components, and other things?
Unread 08-07-2006, 19:38
AKA: Eric Haskins
I thought about this, but thought I would test it(if I could get a good sensor).
Eric Haskins KC9JVH
Unread 08-07-2006, 19:53
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
I think our team used this compass for some testing. Coincidentally, this compass is ready to use with the WPILib and easyC (gotta use the usercode block though). It will give you values between 0-360 degrees, in correlation to magnetic north. The documentation for WPILib says that its very important to watch out for the robot's motors, as they will of course create a magnetic field larger than the earth's field.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 08-07-2006, 19:54
AKA: Eric Haskins
That one looks ok.
Eric Haskins KC9JVH
Unread 09-07-2006, 09:48
Josh Siegel's Avatar
Josh Siegel Josh Siegel is offline
lurker
#0448 (Crandroids)
Josh Siegel will become famous soon enough
Send a message via AIM to Josh Siegel Send a message via MSN to Josh Siegel
Try the Parallax Hitachi HM55B module. It's a bit of a pain to interface, but the results are decent and the price is fair.
http://www.parallax.com/detail.asp?product_id=29123
Unread 26-09-2007, 18:33
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
We have the some compass and we are trying to make it work with a 2004 robot controller. We can't get it to work, please help!
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Where can I get LabVIEW? Hershey LabView and Data Acquisition 1 21-01-2006 14:38
I2C Digital Compass Programming CyberWolf_22 Programming 7 03-01-2005 00:20
Compass/direction sensor Frank(Aflak) Technical Discussion 10 06-04-2003 09:18
Where Can I get A Differential redbeard0531 Technical Discussion 1 07-01-2003 00:42
