Go to Post It's like FIRST saying "Well it was too hard, so we give up. Lets give the kids something easier to do." How is that supposed to inspire kids? - Mike [more]
Unread 13-07-2006, 11:57
Booger's Avatar
Booger Booger is offline
FRC #0637
Booger will become famous soon enough
Axel Diameters
Hey guys, I need some help.
I need to find out the width (diameter) of a standard Robot axle.
The kind that go with these wheels:
http://www.ifirobotics.com/robot-traction-wheels.shtml
3/8" Bearing
or
1/2" Bearing
Thanks!
Collars up!
637
Unread 13-07-2006, 12:06
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Axel Diameters
As listed in the middle of that webpage, you can order either a 3/8" or 1/2" diameter bearing. Therefore, your shaft would be either 3/8" or 1/2".
There are many teams that utilize 3/8" shafts. There are equally as many teams that utilize 1/2" shafts. As a point of reference, the kit chassis is designed to work with 3/8" shafts (or bolts...)
BEN
Unread 13-07-2006, 13:13
Booger's Avatar
FRC #0637
Re: Axel Diameters
thanks homie
Collars up!
637
Unread 13-07-2006, 13:26
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Axel Diameters
We use 3/8"
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 13-07-2006, 15:36
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
Re: Axel Diameters
If you use Grade 8 bolts, 3/8" works fine.
Unread 13-07-2006, 16:18
Billfred's Avatar
Billfred Billfred is offline
Re: Axel Diameters
1293's used 3/8" threaded rod for two seasons with no complaints at all. (After some personal experience with my omnidrive project, however, I'd be inclined to make the switch to bolts.)
Unread 13-07-2006, 16:38
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Axel Diameters
I prefer 1/2" shaft, it is smaller and saves that precious weight.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 13-07-2006, 17:15
Billfred's Avatar
Re: Axel Diameters
Isn't 3/8 less than 1/2?
Unread 13-07-2006, 17:23
FRC #1405
Team Role: Coach
Re: Axel Diameters
minor details.
Unread 13-07-2006, 17:28
AndyB's Avatar
AKA: Andy Burchardt
Re: Axel Diameters
Only in metric...
Unread 14-07-2006, 13:06
Booger's Avatar
FRC #0637
Re: Axel Diameters
hahhaha thats what i was thinking
Collars up!
637
Unread 14-07-2006, 13:20
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Rookie Year: 1996
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: Axel Diameters
If you use 3/8, make sure it is steel.
If you go to 1/2, you can use aluminum - this is our typical shaft size and material.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 14-07-2006, 16:23
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
Team Role: Leadership
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Re: Axel Diameters
3/8" shaft must be supported on both sides, you can probably do without the extra support with 1/2". In 2005 we used 3/8" shaft with the skyway wheels, and slowly the axles bent upwards. They would be fine if it was just our robot driving around on the flat surface, but it had to content with other robots weight some of the times, and being leaned back onto 2 wheels for getting it up onto the cart, etc... Luckily, we just had to undo some bolts, take off some shaft-locks, and slide out the old axles, put new ones in, put wheel and shaft locks on, tension up the chain, and tighten the bolts back up.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 13-07-2006, 17:37
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: Axel Diameters
As another point of reference, 1519 used standard (grade 3) bolts on their 2005 robot for the non-drive wheels and had problems with the axles becoming bent. (We never did get around to switching the grade 3 bolts out for grade 8 bolts, primarily because we had added about 0.75" of thread by hand and didn't want to do that on grade 8 bolts!)
I would think that 3/8" grade 8 bolts would work fine for most FRC robot drive axles.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Mounting encoder/cutting 12 in axel intellec7 FIRST Tech Challenge 8 12-04-2006 12:55
Live axel on kit skyways? Bill_Hancoc Technical Discussion 10 16-03-2006 17:38
Attatching an axel to a wheel Zoheb N Technical Discussion 36 12-12-2005 13:43
Crazy Frog - Axel F Elgin Clock Chit-Chat 23 24-09-2005 22:04
