Go to Post There's no problem another CIM motor wouldn't fix! - Tom Bottiglieri [more]
Unread 17-07-2006, 14:52
jakep jakep is offline
Software Engineer
AKA: Jake Poznanski
FRC #0862 (Lightning Robotics)
jakep has a spectacular aura aboutjakep has a spectacular aura about
Bypass Disable Switch
We are making a robot over the summer using the 2004 RC. However, this is a fully automous robot, and doesn't need to be hooked up via radio (but it can be). We want to be able to let the robot run, with full control of the motors without any OI turned on or anything. However, if you do decide to turn on the OI, the robot should still accept input from it.
My question: Is there anyway to let the RC output to the motors even without an OI plugged in?
Thanks!
Jake Poznanski
Programmer - Team 862 - Lightning Robotics
Microsoft MVP, 2005 - Windows - SPOT Technologies
http://www.spotdev.net
How do you bypass the Operator Interface? jskene Programming 4 31-05-2006 17:50
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
Question about human disable Collmandoman Programming 6 10-03-2005 23:30
