Go to Post This may not be Battlebots but it sure isn't Pretty Pretty Princess Bots. - Andrew Schreiber [more]
Unread 17-07-2006, 17:05
shorton shorton is offline
robotics noob
AKA: Scott
shorton is an unknown quantity at this point
Timing Belt Clamp
HI guys:
I'm working on a project and need a timing belt clamp plate. Specifically one for and XL pitch belt. I can't find them anywhere. Anyone have a good method for attaching a open ended timign belt to something? Or a source for clamping plates?
sdp-si has the specs for just what I need but they dont' stock it anymore
https://sdp-si.com/ss/PDF/80002TMP002.pdf
Thanks in advance for any help.
Scott
Unread 17-07-2006, 17:39
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Timing Belt Clamp
Try a local distributor of XL timing belts (a Gates dealer, for example). They'll usually stock one brand or another of accessories.
But if you don't have a need for extra-precise tooth engagement, you can easily mill such a clamp from bar stock (just use a small milling cutter, and the right spacing).
Unread 17-07-2006, 17:51
robotics noob
AKA: Scott
None of mine do. I've tried. I had to show them pictures of what they were. I did find someone that gave me a quote on a gates clamp. They wanted $50 per for a 3/8" wide clamp. And I need lots of them. Hoping surely someone has them for less. I don't have a mill handy. Need to minimize my "borrowed" mill time.
Thanks, Scott
Unread 17-07-2006, 18:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Will the belt be running in a continuous fashion (as in, every part of the belt will come into contact with a pulley at some point in time)? If not, there are some other ways you can attach it.
Unread 17-07-2006, 19:16
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
screws, zip ties, super glue, quick clamp.
If your more specific, then we can all suggest better ideas. Maybe a diagram?
But if you specifically want somethign like the picture, try taking 2 pieces of timing belt( if the belt your clamping is double sided ) and 2 pieces of some sort of plate and then just run a few bolts through the whole thing
Unread 17-07-2006, 21:03
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
End plates: http://www.mcmaster.com (catalog page 976 & 977 - bottom of pages) Prices in the same $50 range
Unread 17-07-2006, 23:11
robotics noob
AKA: Scott
Thanks guys. It is a reciprocating slider table, the clamp never reaches the pulleys.
I need to "attach" the belt to the sliding part. While I hadn't thought of cable ties, and the thought is actually appealing, I'm making my device for myslef as well as others. I need to to look "manufactured" and zip ties might not pass. However, it is still an interesting thought. I actually have a nice high dollar Thomas and Betts zip tie tensioning and cutoff tool. But alas, would look kind homemade I think. Short term probably OK, but long term it might not work that great.
I had considered just bolting the thing (belt) with a washer to the sheet of Alu it's to mount onto, but figured it's long term wear might not be so good, and again, don't want a DIY looking thing. I had not however considered turning in piece of belt for the interface. I don't think the XL teeth will mesh, but I'll check.
re the McMaster catalog. I wasn't that familiar with them. They too are pricey as well, but at least they have them without a convoluted quoting and ordering process. Thanks for that source, they probably have more I can use from time to time.
I've asked spdi for a quote on their plastic ones maybe they won't be too high.
For those suggesting bolting through the belt, anyone actually do that and have good success? I'll probably be using poly/kevlar belts. My load is about 4 lbs with a 3/8" belt.
Thanks again guys. I'm not a robotics person per se, but I figured the experienced people here woudl have tried some different methods with this problem.
Best, Scott
Unread 17-07-2006, 23:34
Team Role: Teacher
Okay, so if the joint is always in the air, you can do what we did for our 2004 robot (which happened to be 3/8 wide XL belt btw). Take each end of the belt and fold it over itself such that the teeth interlock and you now have a loop on the end. Keep it in this configuration either with a few zip ties or an aluminum cable ferrule (which you need to smash/crimp into place). Then you can join the ends with something like a nice aluminum turnbuckle to allow for tension adjustment.
Unread 18-07-2006, 07:20
robotics noob
AKA: Scott
Thanks, good idea, but I dont' have enought space for that. Only have 4" to do my join, and attach to the slider plate
Unread 18-07-2006, 09:00
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Could you just overlap the two open ends of the belt, and then pop rivet it together? The teeth in the belt will take most of the side load, and the rivets will just hold the two together. Plus, it'll look a lot more "professional" than a few zip ties.
BEN
Unread 18-07-2006, 22:50
robotics noob
AKA: Scott
Thanks very much for the ideas an input guys. Sincerely appreciated.
I finally tracked down where to get some (reasonably) today. One of my timing pulley contacts pointed me to one of them, I found the other. FYI< here they are:
Still high but I ordered some:
www.polytech.com $31.82 45x42mm
then of course I found the best place:
www.brecoflex.com
50x120mm $22.80
They have larger sizes but those weren't in stock. I can cut out the widths I need from these and probably get 4 or more out of each one.
Phew.
Timing Belt and Pulley Joe_Widen Technical Discussion 4 16-01-2006 13:41
Specification for timing belt pulley on large CIM? Larry Barello Motors 10 15-01-2006 12:21
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Timing Belt Recommendations? Eric Reed Technical Discussion 1 10-01-2002 00:25
