Go to Post If you have an opinion on something, it often says more about you than it does that thing. - JVN [more]
Unread 18-07-2006, 14:00
Booger's Avatar
Booger Booger is offline
FRC #0637
Booger will become famous soon enough
Robots tilt
just curious for the teams that have i tilt on their robots with the wheels how big of a tilt is it
Collars up!
637
Unread 18-07-2006, 15:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Robots tilt
I'm immensely confused with what you are asking. Could you clarify your question?
Unread 18-07-2006, 15:11
Booger's Avatar
FRC #0637
Re: Robots tilt
sorry i did word that oddly.
The robot we are building right now has a slight tilt so it can turn easier. does anyone else have this and if so how much of a tilt
Collars up!
637
Unread 18-07-2006, 15:18
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
Re: Robots tilt
I am assuming you are talking about lowering your middle wheel (a 6 wheel drive configuration), if that is so I have seen teams do 1/8th or even quarter inch, it all depends on what you are satisfied with and how you are building your chassis.
Unread 18-07-2006, 15:21
lrdblaster03 lrdblaster03 is offline
FRC #1626
lrdblaster03 is on a distinguished road
Re: Robots tilt
so you mean
regular wheels being like this (vertical) | |
and your tilted wheels being like this / /
or this /
or this /
hope that helps
edit:
i am saying / /, / \,\ / because certain machines tilt their wheels like that.
Unread 18-07-2006, 15:34
B. Flaherty B. Flaherty is offline
AKA: Bill
FRC #1626 (Falcon Robotics)
B. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to behold
Send a message via AIM to B. Flaherty
Re: Robots tilt
I think what lrdblaster03 is talking is something on ATV's. If you notice in this pic, the front wheels are mounted on an angle. So the real question I think is do you mean lowered wheels as in a 6wd configuration, or do want angled wheels for easier turning?
Boston Regional 2007 - Finalists (1626, 121, 1568)
Palmetto Regional 2007 - Finalists (1251, 1626, 1758)
Finger Lakes Regional 2009 - Semi-Finalists (1241, 229, 1626)
Unread 18-07-2006, 15:40
Team Role: Teacher
Re: Robots tilt
I'm not really sure how angled wheels would provide easier turning (I have seen teams do this for some odd reason I've yet to understand), but in a 6wd setup, many teams choose to lower the center wheel so that there can be at most 4 wheels on the ground at any given time. I've found 3/16" offset to be sufficient. Personally, the rocking (tilting) with 3/16" offset was a bit of an annoyance for me. But this was for the Triple Play game where we were trying to place a tetra with a long arm. I'd split the difference between 3/16" and 1/8" and set it at 5/32" (if you keep tolerance on these sort of things to that small). Of course it somewhat depends on what tires/tread you are running. Anything over 3/16" I think would be excessive and anything below 1/8" would be too small.
Unread 18-07-2006, 15:42
Booger's Avatar
FRC #0637
Re: Robots tilt
no no no...Arefin Bari had it right. Im not tilting the wheels im lowering the middle wheel so the robot can tilt
Collars up!
637
Unread 18-07-2006, 17:57
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: Robots tilt
We have done this for the past two years with great success. Our
2004 robot had a four wheel design with 4WD, and we had many problems with turning. Our 2005 and 2006 robots
had 6WD with the center wheel slightly lower than our two outer wheels. If you use a pneumatic wheel for the center, you can adjust how offset the center wheel is.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 18-07-2006, 15:59
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: Robots tilt
This is called camber and it's present on most (if not all?) cars as well. Varying the camber can affect the over- or understeer of the car, but I can't see it having any use on a robot that skid steers.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 18-07-2006, 18:25
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: Robots tilt
What about 116's beautiful implementation of camber (I think that would fit the definition)? They used an extreme angle for their 4 omni wheels in two axis per wheel making the point of the omni in contact with the ground closer to the corners of the physical machine thus providing a much greater footprint for their wheelbase.
I know the middle wheel drop has been established as the thread's intent. I just thought I would throw this out there.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 18-07-2006, 22:45
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Robots tilt
Didn't 229 have something similar to this with 8WD? The two inner-most sets of wheels were lower than the front and back set.
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 18-07-2006, 23:02
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Rookie Year: 1999
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
Re: Robots tilt
25 Doesnt lower their middle wheels at all....
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 18-07-2006, 23:26
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Robots tilt
This year we lower the center wheels about a quarter inch, but also ran a lower pressure in the outer wheels.
Eric Haskins KC9JVH
  #15   Spotlight this post!
Unread 18-07-2006, 23:47
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Re: Robots tilt
60 and 254 both did this for their 2004 machines. Not sure if they still use it but their current drive systems are similar.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
pan & tilt errors itzrobz Programming 2 19-02-2006 19:12
Grabbing Tilt Angle? crossedheart Programming 7 09-02-2006 03:08
CMUCam2 GUI Tilt Question Idaman323 Programming 3 27-01-2006 02:01
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
Weight needed to tilt bridge... archiver 2001 4 23-06-2002 23:43
