Go to Post Coaxial swerve modules with a suspension and differential aren't normal. But on Winnovation they are. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 21-07-2006, 17:31
Goaliexam Goaliexam is offline
AKA: Max
FRC #1656 (Haverford Robotics)
Goaliexam is a jewel in the roughGoaliexam is a jewel in the roughGoaliexam is a jewel in the rough
Send a message via AIM to Goaliexam Send a message via MSN to Goaliexam
Need Help Making Part from Spec
I've been having some major issues generating an Inventor part based on the attached drawing (PDF).
As the filename says, the drawing is the profile of a dome, so the part has to end up as a 3d dome.
I try my best to follow the dimensions as specified, but when I use the Revolve tool on the half-drawing I make, it always leaves a "seam". This is the first part design I've run into in the past two years that I haven't been able to model, so this is driving me crazy.
I would really, really appreciate it if someone could make the part and then attach it to this thread or email it to me (maxcutler@gmail.com).
Unread 21-07-2006, 18:24
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: Need Help Making Part from Spec
you might want to try extruding a cylynder, and then use the fillet to make the dome Ill try to make one
Unread 21-07-2006, 18:48
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
That dome is not spherical, it's elliptical.
Can you attach a screenshot of the sketch you're using and the revolved model? That'd help to see what you mean by 'seam' and to get a better idea of how to help.
Also, how do you know this is a dome? The drawing you attached doesn't provide enough information.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 21-07-2006, 19:10
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
It's overdimensioned, as given, and due to roundoff error, some points aren't going to intersect perfectly. For example, the 18.250 and the 9.125 are redundant (theoretically, if the tolerances were different, this might be OK, but with none specified, it's too much). Also, tangent arcs have to be accounted for—see where you have 0.885 + 9.125 = 10.01? Since the radius is 10.011, it isn't tangent, meaning that there's a bulge there that isn't immediately obvious. If you mean those to be tangent, delete one of the three dimensions (because tangency is implied in conventional drawings). Also, it isn't clear whether you intend tangent radii where the 8.152 and the 10.011 intersect—if tangent, delete one of those dimensions, or a centre point dimension.
The whole problem with overdimensioning is that it allows a part to be interpreted in several ways. If they're overdimensioned but fully consistent, it's a matter of redundancy. If if they're inconsistent, like this one may well be, you risk producing different parts from the same drawing. (Aside: an overdimensioned, toleranced drawing will be inconsistent in all but the most trivial cases, because of tolerance stackup. This condition exists even when a global tolerance is implied, but not printed on each dimension.)
Unread 21-07-2006, 19:14
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
I have made this 2 different ways for reference (and no, not in Inventor but in Solidworks).
I'm guessing you made yours the first way I did and that's why you should have 3 sections actually - 2 seams.
Dome one (on left below) uses actual sketch components and tangent relations between them but indeed has 2 seams.
BTW, check your add up on the print of the .885+9.125 = R10.010 (not R10.011).
Or if those are ALL correct, I refer to dome 2.
Dome 2 (on right below) was made using only the origin as the bottom center of the part and using only the dimensions 9.125 and 11.685.
BTW, the green lines are what I actually sketched in and then revolved both of these.
Of course thinking about this more, there is one more possibility. The 1.828 dimension could be the base of the part (straight extrude up) and then a dome could be on top of that with a width of 9.125 and a height of 9.857 (11.685-1.828). Isn't it great to get drawings supplied to you with so many questions involved?? LOL Try accomplishing work in "the real world" under conditions like this, and oh btw throw in already unreachable deadlines while you are at it.
It's fun.. Trust me. I do this every day.
Ah, touche'.
LOL I'm guessing he was told it was one, cause that is an awfully weird extruded shape we have here if it's a plate or another type of extruded object.
ID:	4527  Click image for larger version
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 21-07-2006, 20:32
AKA: Max
Sorry, I probably should have clarified a bit at the beginning:
Yes, I am sure it is a dome. I cropped out one of the corners, which showed it was actually the spec for an R2-D2 dome (I'm building an R2 for public demos to generate interest, as R2 is one of the few "robotic celebrities"). There is a club on Yahoo Groups that builds full size R2s based on the real thing and the real specs (measured and from insiders at LucasFilms).
As someone mentioned, the bottom 1.828 is actually a ring that the dome sits on top of, and which I didn't bother to remove from the drawing.
Attached is a screencap of the "seam" I was talking about. It doesn't appear when I render in Inventor Studio, but I'm still not convinced that it can't be avoided altogether.
Unread 21-07-2006, 20:34
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
Now if your building a replica of R2D2 for public demos you think the public will notice the fact that it isn't a perfect hemisphere?
About 99.99% of people will never notice, so why make it harder on yourself? Just use a perfect hemisphere.
Just this
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Unread 21-07-2006, 20:38
AKA: Max
Well, that's true, they won't. And I'm buying a dome from the group anyways. But for my personal gratification and for the purpose of training younger team members, we are doing a full CAD of the thing, down to every last screw, all from the blueprints that we've been supplied. So, if someone can help figure out why this is happening, I would appreciate it.
Unread 22-07-2006, 15:59
CraigHickman
Posts: n/a
I can make the part for you... If you're running the compatible version of Inventor. From there, you can see my steps using the browser bar, and that'll allow you to understand how to make parts of these types. If you're running Inventor 10, just shoot me a pm or something and I'll send you the part.
Unread 22-07-2006, 16:17
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
I don't use Inventor, but I've never run across a seam like that appearing in Solidworks. I'd venture to guess that your sketch is wrong, however. It appears as if there's a divet or depression at the top of the dome which ought not be there and the edges at the lower sides are not perpendicular to the bottom as you'd expect from the drawing.
Can you show us the sketch with dimensions? I had no trouble creating the dome in Solidworks, as Elgin has done.
--Madison--
Unread 26-07-2006, 11:34
wilshire's Avatar
wilshire wilshire is offline
OSNAP. a gear flew out of the robot
wilshire is just really nicewilshire is just really nicewilshire is just really nicewilshire is just really nice
Send a message via AIM to wilshire
even if you have a seam it shouldn't make a diiference in the end product once you go into Inventor studio and apply textures and specify materials in the renderings/ animations
the seam should not be an issue when modeling before post production work in studio
AIM: wilshire461
Purdue FIRST Teams
Team 461 -http://www.boilerinvasion.org/
Team 1646 - http://www.precisionguessworks.org/
Team 1747 - www.harrisonboilerrobotics.org
i need specs for motors and pumps in the kit from last years competition plz help SCYTE16 Motors 3 18-11-2004 22:54
I need help w/ making an Invitational Matt Attallah General Forum 6 14-05-2002 19:48
Need Help, from Mentors for Research Steve Shade General Forum 1 25-02-2002 15:49
Need Help, from high school students for research Steve Shade General Forum 0 24-02-2002 22:18
I need Help from you all. nick reynolds Chit-Chat 18 02-11-2001 23:39
