Go to Post Last I checked, this was a competition... just checked again, yup still has Competition in the name. - Andrew Schreiber [more]
Unread 26-07-2006, 15:22
Bruno Inácio's Avatar
Bruno Inácio Bruno Inácio is offline
Bruno Inácio is an unknown quantity at this point
Help IFIRobotics THOR SC
Hello
I'm doing tests with a IFIRobotics THOR Spin Controller and when I turn on the motor without charge(without wheel on the floor), the motor run normally but when I put charge (wheel on the floor), the motor begin to fail......and doesn't load the charge. And when I turn on the motor direct on the batery the charge is loaded.
The weight of the charge is 46.2970751 pounds.
The motor is 24V and 120A continuos.
How can I do this ?????
Thank a lot........
Unread 26-07-2006, 19:30
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Help IFIRobotics THOR SC
Originally Posted by Bruno Inácio
Hello
Thank a lot........
I believe the Thor Spin Controller is to be used for robot parts such as weapons like spinning saw blades, with little to no load on the motor.
Victor 883, Thor 883 Spin Controller were developed for Robot Weapons. The Spin Controller is a Victor 883 SC (90A) or Thor 883 SC (150A) speed controller reprogrammed to function as a single direction spinning-mass controller. Both the forward and reverse components are dedicated to a single direction.
I suggest switching to a Victor speed controller (such as the Victor 885 if you need 24V) if you're going to be using it to drive a wheel motor.
Unread 26-07-2006, 19:47
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
ditto on the victor, The THOR Speed controller is indeed(as far as i Know) meant to be used for revolving objects with little or no load, under the strain of resistance something is likely to break, if the name speed controller confused you from its relation to remote control cars and such, it is the same principal, its just this one is probably not able to handle the load. Try the IFI website, they have a good selection of Victors, sorry if i wasn't more helpful
-RS
Blargha!
Unread 27-07-2006, 03:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Adam and Rohith,
I'm inclined to strongly disagree. The Thor 883 SC is specifically designed to handle ludicrously high currents and current surges. 150A to be specific, and surges of 300A for less than a second. If that's not beefy, I don't know what is. If his motor draws only 120A continuous at stall, then the Thor should just laugh it off. The only reason it's supposedly designed to handle spinning weapons is because it's only capable of one direction, no reverse.
Bruno,
There's obviously a little translation difficulty here, but I'll try to help.
First, are you sure you've wired the motor correctly? Wiring is completely different from a normal Victor. The User's Guide shows that you wire + and - on the battery to + and - on the battery side of the Thor. Then + and - on the Motor side of the Thor BOTH go to ONE side of the motor. The other side of the motor should be connected to + on the battery.
Second, are you sending the motor a full forward signal of 254 from your program? Anything less would tend to weaken the motor.
Third.... I'm out of ideas for the moment, but if you can better describe what you're doing, it might help.
Unread 27-07-2006, 10:31
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Even this statement is a little confusing, but correct. I'll use the "A picture paint a thousand words" approach. See the pic. below.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 01-08-2006, 07:54
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Bruno,
If you have wired the SC correctly, (thanks Bill for the great catch and picture) then what you describe is a typical bad crimp or loose connection type of failure. When the current demand is high (wheel loaded) then the series resistance of a bad connection limits the current supplied to the motor, i.e. low power. Check that all connections are good, tight and soldered/crimped. Check that the breaker feeding that branch circuit is of the correct type and that the SC is showing normal LED function for your data control.
Al
WB9UVJ
www.wildstang.org
________________________
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
An update to ifirobotics.com? bear24rw General Forum 6 01-07-2006 15:56
