Go to Post why do they call them chips if you can't eat them? - Broadside [more]
Unread 29-07-2006, 22:12
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
pic: Vex Teaser: What's Art been up to lately?
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 29-07-2006, 22:14
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Re: pic: Vex Teaser: What's Art been up to lately?
Wow... I've never seen anything like this before. A worm gear driving the 32-tooth (?) gear right to the wheel. Hm... how well does it work? Does the worm gear ever slip from the Vex gear?
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 29-07-2006, 22:23
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Rookie Year: 1999
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Are you going to set this frame up as two or four wheel drive? Or do you just have other plans?
Be sure to post pics of the finished project.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 29-07-2006, 23:51
artdutra04's Avatar
This was mostly just an idea concept of how to simply and efficiently use a worm-gear drive in a small compact space, although I do have enough motors, motor mounting clips, and worm gears to make a 4WD robot using the worm gears.
The motor here has a fairly high amount of torque for something it's size. Under a moderate load it runs at about 2,500 rpm, which is geared down through the worm gear 36:1 to about 69.4 rpm. Just to see how powerful it was, I geared it down an additional stage (using two 60t and two 12t gears, so as to split the load between them) using a 5:1 reduction. It was practically impossible to stop the output shaft of the stump-pulling second reduction.
At the moment I am working on a much more complicated design that mechanically will calculate the difference between two input shafts. For example if both shafts were rotating CCW at the same RPM, the difference between the two would be zero. But if the two input shafts were moving at different speeds the output shaft would rotate in one direction (CW if shaft A is faster, and CCW is shaft B is faster) at a speed proportional to the difference of the two shafts.
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-07-2006, 00:23
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Where did you get the worm gears?
I was a bit frustrated at the lack of worm gears when my arm kept backdriving when I picked up mini tetras.
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 30-07-2006, 01:11
artdutra04's Avatar
http://catalog.pitsco.com/store/
Note: I bought them about two years ago for another project, so I'm not sure if they still carry the exact same gears.
Any 24 pitch (or close enough) gear can mesh with Vex gears...
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-07-2006, 15:49
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
you can also go to kelvin
Unread 16-11-2006, 23:29
jgraber jgraber is offline
jgraber is just really nicejgraber is just really nicejgraber is just really nicejgraber is just really nice
Nice work on the worm gear. Now that it is a few months later, how did it go?
Were you able to make a "South Pointing Chariot"?
Was it to make your holonomic drive "driver centric"?
Links from here might give you some ideas on differentials.
http://en.wikipedia.org/wiki/South_Pointing_Chariot
I thought the screwdrive one has some promise due to no requirement for bevel or planetary gears. You might also consider just doing the integration computationally, based on optical wheel encoders on the drive wheels or drag wheels.
Unread 17-11-2006, 08:26
artdutra04's Avatar
Somewhat. I got about 70% done with it, but at that point the number of gears required to mechanically keep it "pointing South" was taking a toll on the motors and causing the robot to drift badly. This was just meant as a kind of interesting experiment in gearing, and nothing more really.
That's still a work in progress; I have the a KoP gyro at my house, and I'm waiting on an order from Futaba for keyed connectors to make a jumper cable to go from FRC-style female leads on their sensors to the Vex-style male leads. Even once I get them, it probably wouldn't be until a vacation break, like Thanksgiving, when I would actually have enough time to start programming an absolute holonomic drive.
I could of did that, but I just wanted to play around with differential gearing to create a complex mechanical-computer type of thing, just for fun. If I was serious about finding the exact location of the robot, I would have picked something much simpler.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-11-2006, 10:03
Sislith Sislith is offline
FRC #0229 (Division By Zero)
Sislith is on a distinguished road
I'm guessing torque.
Unread 13-01-2007, 23:46
Jared W's Avatar
Jared W Jared W is offline
FTC #3228 (S.P.A.M. FRC #180)
Jared W is just really niceJared W is just really niceJared W is just really niceJared W is just really niceJared W is just really nice
Send a message via AIM to Jared W
hey
hows it coming?
I'd really like to see a movie of the bot in action.
To see how much faster a bigger motor will be.
I hope next season Vex will release beefier motors for torque or speed.
pic: 114 Bumper Art CraigHickman Extra Discussion 6 20-03-2006 20:35
pic: [Teaser]: When Vex meets Tetra artdutra04 Extra Discussion 7 18-09-2005 14:31
Image Discuss: 294 teaser, what's that? CD47-Bot Robot Showcase 4 20-02-2003 00:09
Image Discuss: 294 teaser, what's odd? CD47-Bot Extra Discussion 3 03-02-2003 00:06
change your profile lately? Brandon Martus Announcements 0 04-03-2002 22:21
