Go to Post Isn't that sort of like asking "is that an African or European swallow?" - dlavery [more]
Unread 03-08-2006, 13:40
StargateFan StargateFan is offline
StargateFan is an unknown quantity at this point
Trouble using Kevin Watson's Serial Code with Vex user API
Hi,
I am trying to link the user API supplied with the Vex programming kit to a project using Kevin Watson's serial drivers. In particular, I want the program to receive data through the serial port and then move a servo. I have code that receives data through the serial port but when I tried to add a SetServo() call from the user API, I got a linking error. I linked user_api.o to the project and the error message I received was:
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - could not find definition of symbol 'EnableInterrupt' in file './user_api.o'.
Errors : 1
So then I linked interrupts.o (also supplied by Vex) to the project and I received this error message:
MPLINK 3.90, Linker
Error - could not find definition of symbol 'Old_Port_B' in file './interrupts.o'.
Errors : 1
Then I tried linking the only other .o file supplied by Vex that didn't correspond to any of Kevin's serial port code - Start.o. But once again I received an error:
MPLINK 3.90, Linker
Error - symbol 'txdata' has multiple definitions.
Errors : 1
I have no idea how these files supplied by Vex are implemented since I only have the '.o' files (in the case of user_api.o, I also have a header file but this only contains function protoypes). Has anyone else tried to use the vex user API in this way? Any help would be greatly appreciated.
Thanks.
Using USB with Serial Tower Mick Lego Mindstorm Discussion 11 07-11-2006 09:54
Positioning with Mr. Watson's code Zalumaskov Programming 1 12-02-2005 22:56
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
EDU Demo Code: Serial Data Transmitter Using a State-Machine Kevin Watson Programming 3 28-12-2003 22:56
