Go to Post "Individual": I am the FMS. I don't want to talk to you. Robot: FMS, is this true? I still have stuff for you. Actual FMS: No, what gave you that idea? Are you feeling ok? Repeat. Field Monitor: FTA! We need a counselor! - EricVanWyk [more]
Unread 10-08-2006, 21:18
jakep jakep is offline
Software Engineer
AKA: Jake Poznanski
FRC #0862 (Lightning Robotics)
jakep has a spectacular aura aboutjakep has a spectacular aura about
CIM Voltage and Motor Suggestions
Hey,
I was looking at the CIM Motor specs, and I was wondering if anyone has tried running them at 24 volts? All the spec sheets I saw say 12 Volts, but I was wondering if that was just because FIRST bots are always on a 12 volt system, so performance at higher voltages just isn't reported.
For this one robotics project, we are looking at using 2 CIMs to power it. However, according to our calculations, we will need to double the Horsepower on these motors if they will ever work for our needs. They are rated at ~.34 HP, and we need something that performs at ~.7 HP. My theory was if we doubled the voltage, this would work. However, I'm not sure if this will burn out the motors.
If this is not possible, and our small team is getting a bit desperate with this summer project of ours, can anyone recommend some relatively cheap motor/gearbox combination that would have around 250 inch-pounds of torque at 40amps? I saw: http://www.npcrobotics.com/products/...at=20&mode=gfx
but those just seem way overpriced.
Any help would be greatly appreciated.
Jake Poznanski
Programmer - Team 862 - Lightning Robotics
Microsoft MVP, 2005 - Windows - SPOT Technologies
http://www.spotdev.net
Large CIM motor Wayne Doenges Motors 3 06-03-2006 21:24
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
CIM motor components natis Motors 4 13-01-2006 11:04
CIM-MOTOR source Andrew Schuetze Motors 6 18-05-2005 11:57
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
