Cable Ideas?? Anyone?
Help Anyone!
I am looking for a neat and simple way to hook up the dig I/O's on the '04 board to the dig I/O's on the '05 board (dont ask unless you REALLY wanto to know) so i was thinking i could use a ribbon cable with a connector 3 X 16 on the ends, well.... thats impossable to find..... so then i started to look for Female to Female PWM cable.... well once again... thats impossable to find too... So ANYONE, do you have any ideas of how to do this?....(without using 48 little cables to compleate the job) Thanks, Zak Team 698 |
Re: Cable Ideas?? Anyone?
Well, since one row is always 5v and one row is always ground that simplifies it because you don't need to connect 16 grounds to each other. I think that you should just be able to take the signal row which is 1 x 16 connecters. A ribbon cable and connector would be much easier in that size. or maybe a 2 x 16 with the extra row not connected?
Thanks |
| Ribbon Cable | emusteve | Electrical | 6 | 13-01-2006 16:33 |
| competition cable | Idaman323 | Electrical | 8 | 20-02-2005 12:25 |
| Breaking Cable | WebWader125 | Technical Discussion | 13 | 28-05-2004 16:44 |
| Y-Cable | CaptainPlaid | Technical Discussion | 0 | 13-02-2002 12:55 |
| CABLE | BOOTY BURGLAR | OCCRA | 2 | 30-09-2001 13:10 |
