Wiring battery pack to motor via switch...
OKay... so I've never wired anything before and I want to make a mini poof ball launcher...
How do I wire the battery pack (2 AAA Batter Pack) to a toggle switch and then to a small 1.5-3V DC hobby motor? Again, I don't know jack squat about wiring and don't know where to look to find an answer to this question. |
Re: Wiring battery pack to motor via switch...
picture the electricity flowing like water
it flows out one side of the battery, into one side of the switch, out the other side into one side of the motor, out the other side the back into the other side of the battery when you turn the switch on the power flows round and round when you open the switch the connection is broken, and it stops |
Well, you can get a two AAA battery holder and a toggle switch (or other kind of switch) from Radio Shack. For simplicity, get a toggle switch with only two terminals, kind of like this. This is called an SPST switch, Single Pole, Single Throw.
Then, take one wire from the battery holder, and connect it to one terminal of the switch. Take the other wire from the battery holder and connect it to one wire of the motor. Then take the other wire from the motor, and connect it to the other terminal on the switch. That's all there is to it. You are basically hooking the two motor wires to the two battery pack wires with a switch to "break" the connection along one of them. In this application, it doesn't matter what color goes where. If the motor is running "backwards" swap the wires. Last edited by sanddrag : 15-08-2006 at 16:37. |
Thanks a bunch. I would have never figured that out.
I would also suggest getting some capacitor and resistor and putting it in parallel with the switch, as a snubber.
|-----cap---resistor-----| ----- switch ----------------- This helps protect voltage spikes through your motor, because your motor acts as an inductor. It'll help with your motors lifetime. |
Make sure the switch is rated for at least as much power as you plan to put through it, nothing like melting a toggle switch!
| IR Switch Wiring | sgsdragons | Electrical | 2 | 14-02-2006 03:26 |
| Need Help Wiring Micro Switch/Limiting Switch | Windward | Electrical | 2 | 07-02-2006 18:26 |
| VEX Battery Pack Runtime? | TennBikeBerk | FIRST Tech Challenge | 4 | 04-08-2005 18:12 |
| Wiring a switch | stevex | Electrical | 3 | 16-02-2005 08:31 |
| Wiring Pneumatics Switch | Simpson | Pneumatics | 3 | 11-02-2004 12:32 |
