Go to Post Is the bottom slot just to make the whole thing look like a smiley face, or is it functional? - Chris is me [more]
Go Back   Chief Delphi > Other > VEX
Unread 24-08-2006, 23:07
GlennGraham's Avatar
GlennGraham GlennGraham is offline
AKA: Glenn Graham
FLL #0006 (Shark Bait!)
Team Role: Coach
GlennGraham is an unknown quantity at this point
Wild motors while downloading
I didn't see this issue when I was writing my code as a single main() routine and linking with the easyC libraries, but now that I am implementing the methods in user_routines/user_routines_fast and linking with the Vex_alltimers.lib my robot begins to run the motors and servos randomly while the program is downloading. Once the program has completed its download, things are fine but while the download is taking place it has the nasty habit of driving the motorized arm into the chassis and then some. Could this be an initialization issue or a mismatch of library/firmware versions? If I don't figure this out I will have to unplug motors while downloading or this thing is going to tear itself apart.
-Glenn
Unread 25-08-2006, 02:37
AKA: Glenn Graham
Team Role: Coach
Re: Wild motors while downloading
Ok, I may have answered myself tonight. I realized that this was occuring when I started the robot when it was not connected to the serial port of the computer with radio off. When I connected the robot to the computer before turning it on, I found that there was no activity when I downloaded the program. Not sure if it is just a coincidence or not but it seems to be helping.
Unread 22-09-2006, 19:52
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
I remember this happened last year to us. We had one of the intelitek guys come over in between matches and we found that the CPU got damaged. We replaced it, and then it worked fine.
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
pic: Team 11 Gone Wild aallen88 Extra Discussion 4 01-05-2006 18:53
Southern California Wild-fires Cory Chit-Chat 5 31-10-2003 08:55
Robot gone wild Gui Cavalcanti Technical Discussion 21 20-04-2003 12:47
We Rejected Wild Stang archiver 1999 5 23-06-2002 22:15
