Go to Post When more STEM teams exist outside schools than in them, that will be one indication that a true cultural change has occurred. - gblake [more]
Unread 25-08-2006, 09:46
tacman1123 tacman1123 is offline
AKA: Tac Tacelosky
FRC #1900
tacman1123 is an unknown quantity at this point
Send a message via AIM to tacman1123
Loader for Vex thinks it's FRC
Somehow my EasyC for Vex thinks it's EasyC for FRC. I can't even run iLoader.exe independently, it keeps giving me the message about pressing the PROG button (which only exists on the FRC).
Any idea how to get out of this "mode"? I've done all the obvious stuff. The controller verification returns FRC, it's a complete mystery to me how that could be. I can't even download the Default Code, or the Online Terminal Code.
Even deleting the loader.ini file and restarting didn't help. FWIW, I don't even have EasyC for FRC installed (though I know it's the same code base for EasyC, but since this is just the loader, I'm perplexed).
Tac
Unread 25-08-2006, 10:29
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Loader for Vex thinks it's FRC
It sounds like your PC isn't communicating with the Vex controller successfully.
I've gotten bogus results from "controller verification" even when the cables are completely disconnected.
If the PROG button for Vex on the orange TTL-RS232 converter box isn't helping, then you might try the standard cable swap to see if there's a cable problem (serial cable from PC to Vex converter and phone cable from the converter to the Vex controller).
Unread 25-08-2006, 15:24
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Rookie Year: 1999
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Hi Tac,
I would suggest reinstalling your EasyC for VEX software using this link. If that does not work, please drop me a PM and we'll get it straightened out.
Thanks,
Jessica
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
pic: it's a Vex Holonomic Drive! artdutra04 Robot Showcase 29 01-11-2006 23:08
Vex Programming with MPLAB and IF loader Joohoo Programming 3 27-07-2006 18:18
intelitek loader/vex USB-serial adapter driver MrForbes Programming 2 07-04-2006 13:37
pic: It's a bird.. It's a plane.. It's the 573 Mech Warrior bot! Lisa Perez Robot Showcase 3 27-02-2005 15:09
