Go to Post FIRST isn't for wimps. It never has been. - JaneYoung [more]
Unread 28-08-2006, 17:11
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
main.c
in the main.c
while (1) /* This loop will repeat indefinitely. */
#ifdef _SIMULATOR
statusflag.NEW_SPI_DATA = 1;
#endif
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
{ /* I'm slow! I only execute every 26.2ms because */
/* that's how fast the Master uP gives me data. */
Process_Data_From_Master_uP(); /* You edit this in user_routines.c */
if (autonomous_mode) /* DO NOT CHANGE! */
User_Autonomous_Code(); /* You edit this in user_routines_fast.c */
Process_Data_From_Local_IO(); /* You edit this in user_routines_fast.c */
/* I'm fast! I execute during every loop.*/
} /* while (1) */
shouldn't it be
if(autonomous_mode)
else
otherwise it will be executing Process_Data_From_Master_uP() and then User_Autonomous_Code() in auton, every loop, thus eating up a lot of processor time.
Unread 28-08-2006, 17:24
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Re: main.c
If you take a look at User_Autonomous_Code() in user_routines_fast.c, you'll notice that there is a loop inside the funciton that the controller will not leave until autonomous is over. So no, it shouldn't be since the program can't return to execute Process_Data_From_Master_uP() until autonomous has ended.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 28-08-2006, 21:29
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: main.c
It's also worth mentioning that getdata() isn't called (and the autonomous flag set) until Process_Data_From_Master_uP() is called. Personally, this is a bug to me. Of course, I've also changed that layout anyway, so it doesn't bug me.
Unread 29-08-2006, 02:19
6600gt's Avatar
AKA: Lohit
Re: main.c
whoops...I missed the while loop in user_routines_fast.c...
Anyway, thanks for letting me know
Rewriting main loop Max Lobovsky Programming 4 04-01-2005 18:35
Editing Main.c Astronouth7303 Programming 22 20-02-2004 16:45
Main Circuit Breaker Yan Wang Electrical 6 20-02-2003 10:23
Main Stage archiver 2001 3 24-06-2002 03:06
main driver Kaitlin Palmer Off-Season Events 0 09-04-2002 21:26
