Inverted color mind tricks!
Here's what you do. Take a picture, any picture with vibrant colors and make a gif that will play tricks on your eyes to make a colored image where there is none.
Step 1: Open up photoshop or Gimp (which is what this tutorial was written for), open your image, and draw a dot in the center. Step 2: Make a duplicate of your image and convert it to Greyscale. Follow that by converting it to RGB again. It should now be a black/grey/white image. Step 3: take the original image and invert the colors. Step 4: go to the grey image and create a new layer. Step 5: copy all of the inverted colored image and paste it on top of the layer you created on the grey image. Step 6: You should now have 2 layers, the bottom a greyscaled image of the original and the top an inverted version of teh original. Step 7: Now index your image as you always would with a .gif Step 8: Save your image as <yourname>.gif and save the layers as an animation. Select one frame per layer and set the frame time to 10000 milliseconds or 10 seconds. Step 9: Make sure it works and post it up here! Here's one that I made: ![]() Stare at the dot as it goes through it's frames. Surprise! Last edited by thegathering : 30-08-2006 at 14:00. |
| Camera Picture is Inverted | winners | Programming | 2 | 27-01-2006 20:09 |
| IR signals inverted | Atheist | Electrical | 10 | 08-02-2004 16:27 |
| K3 ... teaching an old K-9 new tricks... | Joe Johnson | Robot Showcase | 5 | 26-01-2003 21:50 |
| Stupid Team Member Tricks | George A. | Chit-Chat | 18 | 03-12-2002 16:25 |
| scouting tips and tricks | Rick | Scouting | 1 | 08-01-2002 00:52 |
