Go to Post Its always good to read the rules yourself rather than listen to "word of mouth" rules. - Killraine [more]
Unread 31-08-2006, 11:50
Billfred's Avatar
Billfred Billfred is offline
Physically securing desktop lab computers
Well, this is one that has me stumped.
I'm the de facto manager of my residence hall's always-open computer lab, and recently we've had a couple of parts walk off. A monitor disappeared last spring, but reappeared around finals. (They've since been locked down far better.) When I first checked out the computers this fall, a keyboard and an ethernet cable were missing. While I know these parts are cheap and available everywhere, it results in downtime for the computers (and, as with most state institutions of late, we're not made of money).
So, with neither the business manager nor myself happy with the situation, I've been looking for a means to keep folks from accessing the cables on the back of the case (thus keeping them from making off with the items), while still allowing folks to access the drives and USB ports in the front. All of the searching I've done hasn't turned up a system that can do both (either you could unplug cables, or you couldn't access drives). My inclination is to build a case over the case from plywood, leaving holes for ventilation and drive access, then perhaps paint it to make it look nice.
Has anyone found a solution to a similar situation?
Unread 31-08-2006, 11:57
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Physically securing desktop lab computers
Ive seen keyboards with USB hub ports, that would allow you to put the entire PC in a locked box, with only the keyboard, mouse and monitor on the table.
Unread 31-08-2006, 12:58
Queen_of_Mascot Queen_of_Mascot is offline
FRC #0334
Queen_of_Mascot will become famous soon enoughQueen_of_Mascot will become famous soon enough
At our school, we have one of the computer labs set up so only the front of the tower is accessible. While it isn't locked down, with the setup, it takes a good amount of time and fidgeting to take away the cables, since its put in a recessed shelf of sorts, with the monitor set up behind glass under the desk... erm...
I really need a pic to show you, but I think the system isn't custom-made, so you could order it en masse. I'll try to get back to you with a pic once the school year starts.
The lockdowns we use at our school leave the front exposed, while protecting the back too, but they're for much older computers... I'm not sure if they make lockdowns like that for newer computers. They're the white metal ones with the two locks on the front, that I'm referring to, with the odd circular keys.
Unread 31-08-2006, 13:59
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Bill,
There is a very popular security rig that uses a piece of covered aircraft cable and glue-on hardware. The armored cable passes through the hardware on each piece, monitor, keyboard and CPU and then has a lock on the end. This ties everything together in one big piece and the glue requires breaking the plastice to remove it. There is also a company that manufactures some really rugged furniture called Anthro. They have a website.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 31-08-2006, 14:04
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
you could bolt a peice of plywood to the computer, at an angle. kinda like this (excuse the crued drawing), that way you woudn't be able to get your hand in to unplug the cable.
Not verry pretty, but it should work, if you use wood screws to screw it down to the table, and bolt it to the computer case, that should deter them enough not to take it. I don't know how your cases are attached so bolting it might not be possible. but i think you get the jist of my idea.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 31-08-2006, 15:53
Eric Finn's Avatar
Eric Finn Eric Finn is offline
FRC #0166 (Chop Shop)
Eric Finn has a spectacular aura aboutEric Finn has a spectacular aura about
Send a message via AIM to Eric Finn
http://www.computersecurity.com/lock... 235f51dc89c05
And just put something over the back to prevent them from unplugging the wires.
It always takes longer than you expect, even when you take into account Hofstadter's Law.
--Hofstadter's Law
Unread 31-08-2006, 16:59
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
I have seen something (can't find it on the internet though...) that is a metal peice that covers the back of the system and if i remember correctly locks (or bolts) at the top. Thier are vent holes and holes for wires but once wires are put through they can't be taken out without a good amount of effort.
Unread 31-08-2006, 17:23
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
You could always take some suggestions from the guys over at this site.
Namely, these guys:
Our marines had taken the order to secure things pretty seriously, because they had done it with two half inch lag bolts. They had drilled straight through the case, the mother board, the bottom of the case, and the desk it was sitting on, to drop the lag bolts in place.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 01-09-2006, 01:58
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Have you looked at the other computer labs on campus to see how they handle the cables? I know that the lab that I worked in had some sort of lock that was put on. It drove us nuts when we had to change the monitor connections for the professor's laptop and back, but it definitely prevented any thefts.
If your campus labs don't have anything like that, call ITR for CSUN's College of Engineering and Computer Science and ask what they use. Send me an email (not PM) if you want their phone number.
indieFan
Unread 01-09-2006, 08:14
Billfred's Avatar
indieFan
The normal method of securing most computer hardware around here is wetware (read: a responsible human in the lab when people are there, and a locked door when they aren't). Of course, we don't have the manpower or money (or space, really) to put a warm body in the lab 24/7, and history has proven that anything that's locked up around here (even if the key is just at the front desk) rarely gets used.
I will look into the lock, though.
Unread 01-09-2006, 08:19
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
Ok well my school uses the products on the following links to secure CPUs, Monitors, and projectors, they are quite easy to install, but the lockdown cables are a bit on the expensive side to wire an entire lab.
http://www.meritline.com/mngek1-anchor-plate-lock.html
http://www.secure-it.com/shop/index.php/cPath/21_22
i hope that helped
-rohith
Blargha!
Unread 02-09-2006, 03:54
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
I was in a computer lab for a class the other day, and while I don't have a picture yet(will take one Tuesday) the cables all went through a hinged piece of metal with two holes in it and then that was wire tied together to make theft of pieces more difficult.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
See FRC488's Lab! :) Madison Chit-Chat 9 14-12-2006 15:00
Vex Lab pieces gdo FIRST Tech Challenge 2 19-12-2005 21:02
Securing interrupt-driven timers Orborde Programming 3 10-02-2005 15:52
Unsafely securing Anderson connector? Andy A. Electrical 20 16-04-2003 22:11
Securing Drill Motor Coupler Ralph Lambert Motors 17 08-02-2003 01:54
