Go to Post Make an informed choice, and feel free to change your mind, if you need to. - Tristan Lall [more]
Unread 06-09-2006, 20:18
CraigHickman
Posts: n/a
pic: Single Op CNC'd wheel
Unread 06-09-2006, 20:19
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: pic: Single Op CNC'd wheel
is there any particular reason for the offset spokes other than machining ease? and have you done any calculations on how much stress it can take?
Unread 06-09-2006, 20:21
CraigHickman
Posts: n/a
The reason for offesetting the spokes is to allow for easy machining. If I put them in the center, another op is added to the CNC process of making this wheel.
As far as strength, I'm hoping it'll be strong enough, as we've never had much problem with similar wheels in the past.
Unread 06-09-2006, 20:24
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Could you explain this in more detail? I don't follow as to why it's another operation.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 06-09-2006, 20:29
CraigHickman
Posts: n/a
In the past for the wheel, we've had the spokes in the center of the wheel, which makes it a two op process: machine out one side, flip, and machine out the other. For this wheel, one side gets machined out, and it's done.
(as far as the two op wheel, here 's an example.)
[edit] I'm realzing now that people are talking about the spokes not coming to exact center on the wheel axel. So as for that reason, I've seen many wheels that don't (vex...), and they've held up quite well. So as far as that's concerned, it's all style. [/edit]
Unread 06-09-2006, 20:38
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
I see. You've moved the spoke back to be flush with one wall of the wheel. I was taking the prior questions about asymmetry to be not about moving the spokes back, but about how they don't intersect the center of the wheel.
--Madison--
pic: IFI-WHEEL v2 InnovationFirst Extra Discussion 15 28-08-2006 20:23
pic: Planetary...Wheel? Matt Krass Extra Discussion 23 27-06-2005 16:05
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 15:51
