IFI Analog Code
When i insert the IFI analog code it wont build right! Any Suggestions?
(Get_Analog_Value(rc_ana_in01) |
Re: IFI Analog Code
Could you post the complete block of code as well as the build error?
Re: IFI Analog Code
It's ok i got it i for got to take out the define_ana_ bla bla bla crap i for got to take it out
Re: IFI Analog Code
Just for your own knowledge, if you're going to respond to your own thread to tell us that you solved your problem, you should try to give as much details about what you did as you can. Someone may have the same problem that you do and may benefit from your solution.
Plus, your post may be the most unintelligible thing that I've read in a while. Part of being an engineer/scientist (or just about any other profession) is being able to express yourself clearly. Don't take that as a slam, but as constructive criticism. Last edited by Dave Scheck : 12-09-2006 at 14:18. |
Re: IFI Analog Code
Dave, are you meaning to say UNintelligible?
If so, I agree, as I couldn't understand David's post either. BEN Quote:
Re: IFI Analog Code
oops...
yeah, I meant unintelligible ![]() |
Re: IFI Analog Code
Ok then!
| Analog-to-Digital Converter Code | Kevin Watson | Programming | 29 | 17-02-2008 13:07 |
| New IFI Default/User and Master Code | Alex698 | Programming | 6 | 28-02-2006 23:04 |
| problem loading code with ifi loader | psych0gambit | Programming | 7 | 25-02-2005 20:43 |
| Analog in on OI: Heads Up! | Astronouth7303 | Programming | 5 | 05-02-2004 17:55 |
| How much code can an IFI controller handle? | Larry Barello | Programming | 7 | 10-02-2002 19:06 |
