Go to Post keep making a difference out there everyone...slowly but surely everyone will catch onto FIRST and then the world will be a better place :) - tiffany34990 [more]
Unread 12-09-2006, 19:25
i like dirt's Avatar
i like dirt i like dirt is offline
"Dude, I Know this Stuff!"
AKA: Sagar
FRC #1694 (Dr. Phillips Tech)
Team Role: Electrical
i like dirt will become famous soon enoughi like dirt will become famous soon enough
Float Design
Hello, CD
Me and a couple other members of our team have just been assigned to create a float for our team in our school's Homecoming Parade.
I was just wondering how we should tackle this task? Like what type of structure, costs, materials,advertising. Any Ideas will help.
KILLER TOFU!!!!
Unread 12-09-2006, 19:42
CraigHickman
Posts: n/a
Re: Float Design
Our club has not built our own float, but has instead made the class floats move. Here's what we have to say:
1. Only work on the structure, let them decorate it. They like it a lot better this way, and it helps to have two teams to tackle different tasks: one to make it move, one to decorate.
2. Wood, Wood, Wood. You'll need more wood than you think at first. This year I'm in charge of making a giant moving spongebob, and I can tell it's going to be quite a large project. Also, wood is fast and easy to work with, and it doesn't have to be nearly as precise as metal
3. Make sure your breakers are correct. We had an issue with this, as a drivetrain guy did the wiring. Flaming control panels are not fun mid parade.
4. Isolate the battery/electronics. This is a general safety tip, as in case of emergency, it's better to not risk all that flameable tissue paper. Besides, though colored flames look pretty, the fire department has this issue with large moving bonfires.
5. Limit the complexity of moving objects. If it's more than three stages of chain just to make one thing spin, it's too complex. We had an issue with this, and it was annoying to tune/get running.
6. Don't let just anyone run the float without the team in charge of it present. This resulted in our beautifully designed float being in a non working state for the actual parade. And if something is supposed to be moving, and isn't, it just doesn't look that cool.
7. Make all the designs very robust and simple. It needs to be reliable, as it will be running more than you think.
8. Make it (the moving mechanism) easy to access. Due to Murphy's law, something will break 5 minutes before the parade starts. Therefore it makes sense to be able to quickly access everything for quick fixes.
Hope that helps, and if you have any more questions, just pm or email me!
Unread 12-09-2006, 22:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Float Design
Hi,
I am the Construction Co-Chair for the 2006 Cal Poly Pomona Tournament of Roses Parade float. When finished, it is a quite massive vehicle (18 feet wide, 55 feet long, 16 feet tall) and made primarily from steel. There are TONS of pictures on our website www.cpprosefloat.org This is probably a bit more elaborate than you are looking for, but hopefully it'll give you some ideas. I'd be glad to try to answer any specific questions you have.
Unread 13-09-2006, 00:21
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: Float Design
I have cut costs down on some floats by stretching fabic on frames (wood or pvc) as where other poeple use plywood. of course the fabric was painted and was really effective, we won third @ UCF homecoming so it musta been good.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
[Official 2007 Game Design] OK, so YOU design the 2007 game... dlavery FRC Game Design 44 17-12-2006 17:05
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
Float in MPLAB capenga Programming 1 18-02-2005 06:44
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
DB Design Jack FIRST Scouting Network 0 17-06-2003 01:14
