Go to Post Whenever we loose a committed member of FRC, our entire country pays the price. - daniel_dsouza [more]
Unread 19-09-2006, 20:36
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
pic: Inside the torque multiplier
Richard Wallace
since 2003
Last edited by Richard Wallace : 19-09-2006 at 20:42. Reason: repeated CD Media text for convenience
Unread 19-09-2006, 20:37
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Team Role: Mechanical
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Re: pic: Inside the torque multiplier
Interesting....that has the same principle as an oil pump...but i wonder how it 'multiplies' torque
looks messey though
MechWarriors 573
Unread 19-09-2006, 20:51
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
looks messey though
It multiplies the torque, by dividing the revolutions per minute. Since the power output cannot be greater than the power input.
Basically, its a gear reduction.
This is useful
Unread 19-09-2006, 21:32
Rookie Year: 1996
This is useful
Thanks for that link, Conor. The handtorque multiplier example shown there is an industrial grade unit with an epicyclic gear set.
The low-cost (read: Harbor Freight) unit does not have a conventional epicyclic gear set. It appears to operate differently. The input gear center hole pilots on an eccentric section of the input shaft, causing its tooth engagement point on the outer ring to revolve. The input gear revolves 33 times for every single revolution of the output gear, and both gears react against the teeth of the stationary ring. And as mentioned earlier, the gears are loosely pinned together in six places, allowing relative freedom of movement between the gears of about one tooth pitch. Also, the output gear rotation is opposite that of the input gear. So to loosen a lug nut you turn the crank clockwise. Maybe this really is a kind of epicyclic gear set, with the sun gear replaced by an eccentric -- sort of like a gear with one tooth?
I'm hoping someone with more experience in gear set design will jump in here an enlighten us to the mystery of this gear system. I am actually an electrical engineer, with just enough knowledge of mechanisms to be dangerous.
Richard Wallace
since 2003
Unread 19-09-2006, 22:00
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
looks messey though
This is a good question: anybody have a good explanation for an epicyclic gear drive?
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 20-09-2006, 07:11
John Neun John Neun is offline
FRC #0020 (Rocketeers)
Rookie Year: 2000
John Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond reputeJohn Neun has a reputation beyond repute
These are great drives because you get tremendous turndown (torque multiplication) in a very compact package. There is a company called Harmonic (at least that is what they used to be called) that makes a similar drive but very elegant. The inner "gear" is actually flexible, such that it is deformed into an ellipse that meshes the ring gear in two places. The teeth are very fine pitch. Therefore, the one tooth difference between inner and outer gears makes for a huge turndown (something like 75:1 or better in a transmission not much larger than a coupling), and the drive is incredibly smooth. The biggest advantage in our application was the lack of any perceptible gear noise, as the drive was for cooling rolls on a polycarbonate sheet line. Any ripple would have produced an optically perceptible imperfection in the lexan. Very cool, but expensive.
Unread 20-09-2006, 09:23
Rookie Year: 1996
Thanks, John. For many years I've been using a Harmonic Drive Model PCR-5C 100:1 reducer as part of low-speed motor tester. [Note: this reducer is now obsolete, replaced by the CSG series, I think.] We use this tester to measure cogging, ripple, and frictional torques developed by brushless permanent magnet motors at 2 RPM. The Harmonic Drive unit operates with negligible backlash, is very quiet, and as you pointed out it provides very high reduction ratio in a compact package. It is also not cheap.
I did not recognize the similarity of the harmonic drive to the low-cost lugnut remover gear set.
Richard Wallace
since 2003
Unread 20-09-2006, 16:06
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Substitute the word planetary for epicyclic. It's another word for the same thing.
The wiki comes through with a decent explanation, http://en.wikipedia.org/wiki/Epicyclic_gearing but it won't touch a good machine design book like Shigley or Norton. The Lindeburg PE exam reference book is the best explanation I have but I can't post it.
http://ppi2pass.com/ppi/PPIShop
Pete
edit: When you say it operates like an oil pump I'm a little confused. Do you mean it's like a gearotor hydraulic pump?
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 20-09-2006, 16:37
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
The way the harmonic drives operate is explained here in detail: http://www.harmonicdrive.net/referen...ingprinciples/
This is an interesting explanation of how a multi-speed planetary transmission operates: http://www.railcar.co.uk/mechanical/gears/work.htm This was actually for a locomotive: http://www.railcar.co.uk/mechanical/gears/intro.htm
And this is a great animation. You can click the buttons and see the different modes of operation: http://www.mekanizmalar.com/transmission.html
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-08-2007, 17:45
Rookie Year: 1996
I usually don't like to revive dead threads. However, when I saw a description of how hypocycloidal gearing works, it immediately reminded me of the lugnut remover. The animation in the link above seems to capture the operation of that gadget better than any of the previous explanations.
Richard Wallace
since 2003
pic: Inside Team 698 Teaser Alex698 Extra Discussion 3 09-03-2006 00:46
A tour inside the RC Rickertsen2 Control System 15 10-01-2006 18:07
Information on gears inside the FP Gear Box? David Guzman Technical Discussion 2 19-05-2005 23:09
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
