Go to Post It's official: we've run out of things to talk about. - Jessica Boucher [more]
Unread 20-09-2006, 14:07
Cirrussport Cirrussport is offline
Cirrussport is an unknown quantity at this point
CIM generator
I built a gas generator using 2 cim motors driven off the shaft of a Small 29cc 4 stroke gas trimmer engine. I am able to get a fairly decent, stable 18v out of it running in parrallel. Or at a lower rpm i can easily get 18v in series.
Just wondering. I want to run 2 dewalt 18v DC925 motor/transmission combos off of this. Just wondering if the cims will produce enough amps to power both.
I have a separate regulator to make the 12vs for the rest of the robots electircal system.
Does anyone see any problems with this? Will the cim bearings/coils stand up to this?
And does anyone know what kind of amperage i can expect out of this setup.
Thanks in advance.
Signal/Function Generator Ronald_raygun Electrical 0 01-07-2005 10:52
Vacuum Generator Peter Matteson Pneumatics 0 04-02-2005 15:58
Vacuum Generator Peter Matteson Technical Discussion 0 04-02-2005 15:58
DC Motor running as a Generator IrisLab Motors 16 12-01-2004 12:23
Random Match Generator Challenge Mark Hamilton Programming 13 09-01-2004 16:18
