Go to Post As Murphy as my witness, things happen and will continue to happen. - Pavan Dave [more]
Unread 21-09-2006, 02:08
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
pic: CRT Goes To The Football Game!
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 21-09-2006, 02:09
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Re: pic: CRT Goes To The Football Game!
That's awsome!
Did you have to reload? Or did you have multiple cylinders?
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 21-09-2006, 10:02
Kyle A's Avatar
Kyle A Kyle A is offline
If it ain't broke don't fix it!
AKA: K Adams
FRC #0306 (CRT(Corry Robotics Team))
Kyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud of
Send a message via AIM to Kyle A Send a message via Yahoo to Kyle A
Yes we do have to reload after every shot, but we were only shooting when it was a 1in 10 for our team and when there was a touchdown. So we had plenty of time to reload and pressurize the tank.
Corry Robotics Team 306 1999-2015
Unread 21-09-2006, 21:06
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Any whitepaper on this? We would love to use it ourselves for the same purpose.
Unread 22-09-2006, 19:08
FRC #0306 (CRT)
No white paper that I know of, but it's quite simple.
1. Buy ~ 3" pressure rated schedule 40 PVC pipe, depending on what diameter barrel you want. 3" works well for t-shirts and small foam balls. You'll be using this for both the barrel and tank.
2. Buy an irrigation valve with large diameter bore. (Ours is a 3/4" throat, 24 volt irrigation valve from Lowes. It ran about $17 and has worked perfectly. It's just a simple solenoid, so 12 volts works fine with it)
3. Buy appropriate end caps, fittings, tubing, and good, relatively high pressure PVC glue (It'll tell you it's best rating on the can. Ours is a tan glue)
4. Put it together.
It's not much of a how to, but it'll get you started. Um, one thing concerning the PVC air tank- conversation recently generally agrees that even pressure rated pipe has a serious possibility of catastrophic failure, so be careful if using our setup. We are considering adding some shielding or containment devices around the tank just in case. Even better, use an actual air tank. But it's important to have all openings be at least the size of the valve gate, otherwise you'll bottleneck.
As for the barrel, just start with a long length, and test it, shortening the barrel until you get good results. Different projectiles will like different lengths.
Have fun, ours never seems to get old, and the community really likes it, so it's really a good investment! Any more questions you have I'd be happy to answer.
-Sir Francis Bacon
-Albert Einstein
Unread 22-09-2006, 20:21
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
That is awesome! Keep up the good work!
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 23-09-2006, 18:26
wendymom's Avatar
wendymom wendymom is offline
Team Mom
AKA: Wendy Austin
FRC #5816 (Gra-V)
wendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond reputewendymom has a reputation beyond repute
I want one!!!!!! Exploding Bacon....are you listening???????
Its really cool.
The "anything goes" game! mechanicalbrain Games/Trivia 30 04-09-2006 13:34
pic: The BEAST Goes Down! CD47-Bot Extra Discussion 5 22-04-2004 11:14
pic: 73 goes for the doubler at Buckeye CD47-Bot Extra Discussion 5 01-04-2004 05:28
FIRST Annual, All Star Football Game or Mini Tornement archiver 2000 11 23-06-2002 22:14
