Go to Post Overpowered? You only took out half the building... Knock the rest down then get back to me. - sodizzle [more]
Unread 21-09-2006, 14:45
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
FIRST air cannon robots PVC??
When I get a bit more time, I'll add links to the various threads on C.D. on this topic.
My question is how / where does one get a definitive answer as to the pneumatic pressure rating of schedule 40 PVC? I was intrigued by the team fusion air canon last year and then decided to add one to our 2005 robot this August. I'll post a picture of the prototype mounted on my classroom workbench. It works okay. Based upon three weeks of development, what I perceive to be limiting the performance is the restriction of air flow from the storage tank via the 0.5 inch fitting. Everything else is the same 1" diameter as the sprinkler valve and then expands to the 3" diameter at the back of the muzzle.
I've seen about three cannon systems which are using PVC pipe as the pressurized air storage system here on C.D. People have commented that PVC pressure ratings are for water systems and in fact the fine print at the store indicates use for water only.
My fear is that a bump into a doorway or drop on the floor may start a crack in the PVC pipe and eventual lead to catastrophic failure.
How do I know if I am being overly cautious or just being prudent?
APS
Toltech prototype
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
potato cannon northendchopper Chit-Chat 14 16-12-2009 12:19
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
Too Powerful cannon? I Eat Robots829 Chit-Chat 15 03-02-2006 00:19
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Trouble finding flat pvc sch 40 PVC caps Gdeaver Kit & Additional Hardware 8 12-01-2005 14:21
