Go to Post People in FIRST ARE lucky, because they are living a very creative adventure which just doesn't let up, and that is okay. Who wants to sit there watching TV and being a spectator anyway. - DougHogg [more]
Unread 01-10-2006, 11:21
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
Team Role: Mechanical
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: What machines are you using? (CNC, lathes, mills, 3-in-1 machines?)
all we have in the shop is a lathe, a drill press, a band saw, and a mini mill thats so off center and uncalibrated that we never use it
Championship - Delphi "Driving Tomorrows Technology"
Unread 02-11-2006, 22:49
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Our mentor just bought a small upright band saw made by Delta. Basically it's a piece of junk. My friend Dom and I seem to be the only ones who understand how to get it to cut strait, go figure. It also is terrible at cutting vex parts(dremel FTW). Also, if anyones looking at CNC lathes, check out STAR CNC tool corp. I've had the privilege of using some of their machines, and I wish I had room in my basement for one. That and my uncle works for them so he knows how to fix them when i forget the limits and knock and axis off the ballscrew . Don't look at me like that, I needed an extra half an inch of travel and it looked like It would make it
And your always welcome at my house Mark, as long as your bringing the donuts
Edit: If it's uncalibrated then calibrate it!!! I've worked around machine shops since I was little and can't STAND uncalibrated machines, whether their mine or not. You can make alot of weight saving stuff on those puppies. If your like my team then you tend to use 5-20 washers to get the right spacing between parts sometimes. With a mini-lathe, a piece of aluminum rod, and a few minutes you can make a lightweight spacer . Or you could be like my team and tell me not to make the spacer, and then scramble at the regional to get under the weight limit.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 03-11-2006, 11:55
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
hey as an update aside from the shop where i work and the fdm machine
we got some old tape drive changing machines... and inside was a nice, sturdy step motor driven x,y table...
so either that way or some other way we'll probably have a plasma cutter this year.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
What Motors/Drivetrains are YOU using? IA-Howitzer Motors 16 27-02-2005 15:01
State Machines doyler Programming 7 11-01-2005 00:53
pic: machines CD47-Bot Extra Discussion 20 27-02-2004 00:24
Sewing Machines tenfour Kit & Additional Hardware 0 07-01-2003 17:16
# of limbo machines? archiver 2000 16 23-06-2002 23:05
