Go to Post You have to admit, Regionals are pretty strange places, albiet cool - Otaku [more]
Unread 18-10-2006, 15:52
lupjohn's Avatar
lupjohn lupjohn is offline
AKA: Larry Upjohn
FRC #0692 (FemBots)
lupjohn is an unknown quantity at this point
Re: Gumstix Programming
Originally Posted by EHaskins
I've been considering purchasing a gumstix computer( netstix 200xm-cf, or waysmall 400mhz). I know many teams have used gumsitxs on their robots, and I'm curious how you've programmed them?
I don't have access to a linux computer , and I have never done any linux programming , but I have done lots of Windows and embedded programming. I would appreciate any linux programming resources, or code for gumstixs, but more than anything I would like any comments on gumsitx, or any other systems you've used.
I know someone will ask so I'll say now. I plan to use the gumstix in a position tracking system, and poisably connect a web cam to replace the $&%#$^ CUMCam. I also want to be able to save a record of all inputs, motor outputs, and any other data I can so I can replay a match virtually to help identify problems.
EDIT: After looking through the gumstix models I'm leaning towards a Waysmall due to the serial ports.
Thanks,
Eric Haskins
Eric and all;
Microsoft has intro'd their robotics suite which drew dubious comments in previous threads. However I have read the interviews in several pubs and actually downloaded the August edition to play with. It would seem to me if this product is successful then the gumstix/winCE/VS2005( or facimile of the same) environment could be in the future of at least FRC. I would not be supprised if the DVD of the Robotic Studio ends up in the KOP for 2007. First's close ties with MIT would predict that some sort of global robotics software environment will eventually become part of the KOP of the near future. LRU.
Unread 23-10-2006, 15:47
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
I don't think this will happen any time soon. MSRS doesn't have runtime support for Windows CE yet, so you would need to have Windows XP Embedded (and a 32-bit PC) running on your robot, which isn't practical at all.
If we were to get any of the new Microsoft development technology to play with next year I would think that it would be the .NET Micro Framework, but this is unlikely. The IFI RC would require different hardware and I don't think Microchip would be too receptive to moving away from their microcontroller line.
Unread 28-11-2006, 16:44
Max2007 Max2007 is offline
Max2007 is an unknown quantity at this point
All,
Totally new to the world of robotics, but have been doing some reading and the gumstix looks like a good starting place , as its a new chip. Most of the pre-built bots I seem are all based around PIC chips, which seem very old now.
Looking at this thread it seems some people have been able to get the gumstix working with .NET, which for me is good news as that my background. Would be could if someone could PM or post an idiot guide to how to do this and what stix they bought. As the idea of linux is one I would like to avoid
Thanks in advance
M
Unread 01-12-2006, 01:46
gobeavs's Avatar
gobeavs gobeavs is offline
linux advocate
AKA: Ross
None #1425 (Wilsonville Robotics)
gobeavs will become famous soon enoughgobeavs will become famous soon enough
Send a message via AIM to gobeavs
If I'm familiar with linux (gui and command line), is a gumstix easy to get running? Or is there some setup that needs to be done or any kind of learning curve?
"Never in the face of human conflict has so much been owed by so many to so few."
- Winston Churchill on the RAF in WWII
Unread 02-12-2006, 14:22
fowlerm's Avatar
AKA: Matthew Fowler
You shouldn't have any problem. The Gumstix boards come preloaded with u-boot (the bootloader) and a 2.4.x kernel. I am not that familiar with the other Linux software that's included since I reflash them with a CE image as soon as I get them.
Unread 04-12-2006, 10:21
fowlerm's Avatar
AKA: Matthew Fowler
I don't have a setup guide for Windows CE on the Gumstix. I may write one in the future, but right now you can look at the documentation that others have contributed to the GotDotNet workspace for the Drumstix project.
See the above posts for hardware requirements.
Mini-ITX or Gumstix? lemoneasy Programming 1 10-04-2006 19:50
VEX or Gumstix? gobeavs Programming 5 06-04-2006 01:04
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
programming JasonWestHigh Technical Discussion 1 13-01-2003 20:54
programming archiver 2000 2 23-06-2002 22:59
