Camera Programming
I was wondering, does anybody have some code that they used to get the robot to respond to the cameras values? Last year we got our camera to track but we couldn't figure out a way to use those values to make some code that would work. Any help is greatly appreciated.
Re: Camera Programming
I've used Kevin's code the last two years, modifying this year's code to set the camera to autotrack and report servo values.
To handle the camera, you need to:
The data is dumped into the variable T_Packet_Data. It contains (by default):
If you have done all this, and are having problems getting the robot to "respond", you will have to go into more detail. |
Thanks, I'll try that and see what happens
| ****Team 40 Checkmate easyC Camera Programming Workshop**** | Kingofl337 | Programming | 0 | 05-09-2006 16:21 |
| Need help Programming and wiring camera! | Amisca | Programming | 1 | 14-02-2006 18:37 |
| Camera doesn't have firmware? no programming? | GraphicArtDesig | Programming | 6 | 19-01-2006 20:10 |
| Camera Help (New to Camera Programming) | Idaman323 | Programming | 6 | 14-01-2006 03:56 |
| Should there be a section for the 'camera' under 'Programming' | Bharat Nain | CD Forum Support | 6 | 25-01-2005 22:23 |
