Go to Post We might just dip the entire bot in a Locktite bath before bagging. - Kevin Ray [more]
Unread 04-10-2006, 15:33
RudimentaryPeni's Avatar
RudimentaryPeni RudimentaryPeni is offline
Registered Abuser
AKA: "Garth"
#1110 (Binary Bulldogs)
Team Role: Mechanical
RudimentaryPeni is a jewel in the roughRudimentaryPeni is a jewel in the roughRudimentaryPeni is a jewel in the rough
Send a message via AIM to RudimentaryPeni
Electric Bicycle
I have this bike I aquired, nothing special, just a regular ten speed. It's nothing like my schwinn beach cruiser. So I started thinking... how can I FIRST this bike up. Then it came to me, I should make it motorized! I had an idea to put a motor by the sprocket by the pedals, but i cant just hook a battery to a motor. Any one else have any ideas, or tips, or have you done this already?
Matt Blake is no more politics!
Yes, That IS me on the robot, on my teams site!
The Coolest Guy On Myspace
Unread 04-10-2006, 15:45
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Electric Bicycle
you are right, you need an ON/OFF switch at least
that may sound simplistic, but if you can pedal when you want to go slow, why not have the motor be your turbo-boost?
usually when you are riding a bike you want to go as fast as possible, right?
Unread 04-10-2006, 16:35
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
two of the big CIMS geared together onto one sprocket which goes to the wheel. and a few FIRST batteries of course
Unread 04-10-2006, 17:07
one way to have the motor stay independant of the pedals is to put the motor on the front wheel
then you can motor and pedal at the same time if you want for climbing hills, or coast the pedals while the motor is active, or let the motor freewheel and pedal the bike (at slower speeds).
it should be possible to put the back wheel from a 10 speed on the front of a bike, and link the motor with a chain. This would let the front wheel freespin when the motor is not driving it.
Unread 05-10-2006, 14:01
Registered Abuser
AKA: "Garth"
i apreciate the suggestions. I also am considering making a generator so ill never have to recharge the batteries, any ideas, schematics?
Unread 05-10-2006, 14:14
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
While theorectically possible it may require a front fork modification. The rear forks are wider and off set and inch or so to keep the wheel centered while still having the gear cassette on it.
MechWarriors 573
Unread 05-10-2006, 14:24
Im willing to bet one could grab the ends of the fork and pull it apart enough to get the rear wheel to fit!
esp if the fork is steel. Some of the exotic light weight forks might break if you try to bend them.
Can We Use a Bicycle Tire and Rim? waialua359 Technical Discussion 16 17-01-2006 09:23
Carbon Fiber Bicycle Fabrication Peter Matteson Technical Discussion 5 07-12-2004 18:31
Bicycle Cables Anyone? SiliconKnight Rules/Strategy 5 26-01-2003 05:56
Bicycle riding Robot Brandon Martus Chit-Chat 4 13-05-2002 22:41
