Ok, now my computer loads programs. The default loads, but only makes one wheel and our gatherer work. When I try to load my program, however, The robot is completely unresponsive of the joysticks.
This is my code from user_routines : void Default_Routine(void) { /*---------- Analog Inputs (Joysticks) to PWM Outputs----------------------- *-------------------------------------------------------------------------- * This maps the joystick axes to specific PWM outputs. */ /* pwm01 = p1_y; pwm02 = p2_y; pwm03 = p3_y; pwm04 = p4_y; pwm05 = p1_x; pwm06 = p2_x; pwm07 = p3_x; pwm08 = p4_x; pwm09 = p1_wheel; pwm10 = p2_wheel; pwm11 = p3_wheel; pwm12 = p4_wheel; */ /*---------- 1 Joystick Drive ---------------------------------------------- *-------------------------------------------------------------------------- * This code mixes the Y and X axis on Port 1 to allow one joystick drive. * Joystick forward = Robot forward * Joystick backward = Robot backward * Joystick right = Robot rotates right * Joystick left = Robot rotates left * Connect the right drive motors to PWM13 and/or PWM14 on the RC. * Connect the left drive motors to PWM15 and/or PWM16 on the RC. */ // pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127); // pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127); if (p1_sw_trig == 1) { pwm03 = 200; // turn on the shooters pwm04 = 200; if (p2_sw_top == 0) { relay1_fwd = 0; relay1_rev = 0; //no gather movement durring aiming pwm08 = 120; //closed if (p2_sw_trig == 1) { pwm06 = p2_x/4; //pan pwm07 = p2_y/4; //tilt } else { pwm06 = 127; pwm07 = 127; //NOTE NOTE! this is for the auto aim code } } else { pwm08 = 50; //open } if (p2_sw_top == 1) { relay1_fwd = 1; //with both tops down, activates gatherer relay1_rev = 0; } else { relay1_fwd = 0; relay1_rev = 0; } } else { pwm01 = p1_y; //again, make a #define, probably pwm_1 pwm02 = p2_y; //Also a #define, pwm_2, make sure p1 joystic is on right } if (p1_sw_top == 1 && p2_sw_top == 0) { relay1_fwd = 0; relay1_rev = 1; //rev gatherer } else if (p1_sw_top == 0 && p2_sw_top == 1) { relay1_fwd = 1; relay1_rev = 0; } else { relay1_fwd = 0; relay1_rev = 0; } Also, when the terminal window opens, it reads <IFI> and thats it. (Unless it's the default code, and then it only reads the information for the joystick in port one ANY HELP??? PLEASE??? |
Re: Program doesn't effect robot
Are you sure that all the PWM wires are connected properly in correspondence with the program(s)?
Did you try inserting printfs for the joystick values (including buttons), to make sure the robot is getting the joystick input?
printf("%d\t%d\t%d\t%d\n", p1_y, p2_y, p2_sw_trig, p2_sw_top); Is everything plugged in (the motors)? I'm not sure if it was a problem with copying, but there's no ending curly brace for Default_Routine. Oh, also, a few other things, that probably aren't causing your problem, but might cause other problems: (In the code, I changed all "x == 1" to just "x" and "x == 0" to just "!x". It's still exactly the same.) Code:
if (p2_sw_trig)
pwm06 = p2_x / 4; //pan
pwm07 = p2_y / 4; //tilt
Code:
if (!p2_sw_top)
//some code here...
else
//more code...
if (p2_sw_top)
//even more code...
Make doubly sure the call to Default_Routine() is not commented out. (If you're starting with the 2006 code with camera support, it is unless you changed it.)
How many Joistick can I use in the competition...
can anyone help explain rewriting the c programming were a rookie team struggling with it
Steve |
how to wire the pressure switch right for our nuematics
| Robot doesn't drive straight | bush | Control System | 14 | 09-02-2006 00:00 |
| How to program Hall Effect sensors. | chantilly_team | Programming | 1 | 17-02-2005 14:08 |
| How to keep a program running at a school which doesn't get it? | Jimmy | General Forum | 9 | 03-04-2003 10:08 |
| Minor Problem, our robot DOESN'T work! | Cobra | Motors | 1 | 15-02-2003 14:43 |
| Robot reset on OI doesn't work | Carl Owenby | General Forum | 1 | 07-02-2003 07:23 |
