Go to Post I used to wonder if the FRC staff would read the CD game hint posts and just laugh to themselves..now I know they do. - rachelholladay [more]
Unread 06-10-2006, 02:55
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
New AndyMark Shifters!
Hopefully this thread doesn't exist yet...
AndyMark has new servo shifting transmission. Gotta hand it to them for eliminating the need for a pneumatic system to shift. This is awesome news!!
http://andymark.biz/products.htm
Thank you AndyMark!
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 06-10-2006, 07:28
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Re: New AndyMark Shifters!
No my question for Andy and Mark is, will there be an upgrade kit available to convert a spare gen 2 to a servo shift?
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 06-10-2006, 08:21
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Yes, we will have one ready. It's just not on the site yet. The tricky part to converting from pneumatic to servo shift would be swapping out the small "shift shaft" that is connected to the dog gear by a 3/32"x1" roll pin. If you're good at removing that roll pin, then it will be easy.
Andy B.
ps... man, Gabe, you're quick. This was put on our website at midnight last night.
Unread 06-10-2006, 08:52
[quote=Andy Baker]Yes, we will have one ready. It's just not on the site yet. The tricky part to converting from pneumatic to servo shift would be swapping out the small "shift shaft" that is connected to the dog gear by a 3/32"x1" roll pin. If you're good at removing that roll pin, then it will be easy.
[quote]
Shouldn't be a problem. When we built dog shifters for the first time in '04 it took a few attempts to get things right so we have experence.
I'm getting the 404 on gifts also, but I got my t-shirt already. Just another reason to drive halfway across the country to go to IRI.
Thank-you 294 & 67
Unread 06-10-2006, 09:38
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
Looks great. We're going to try to implement such a system on our custom gearboxes, so I have a couple performance questions:
-How long does it take to shift? (and what is the throw in that time period?-ours needs about 1 1/2" travel in as little time as possible)
-I don't know a lot about servos, so could a longer arm on the servo be used to decrease shift time? Would the servo be strong enough?
-How long could said arm be before the servo wouldn't have enough power to shift? Thanks. -JH
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
Unread 06-10-2006, 10:32
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Looks great.
Two years ago we built and installed custom servo shifting gearboxes with the DeWalt motors and casings in our robot...so much torque that it bent the chassis - we had to switch out for the standard FIRST gearboxes with CIM's.
Unread 06-10-2006, 11:01
Rookie Year: 1998
The Acroname page for this product gives good specs:
60 degrees of throw in 0.19 seconds
41.6 oz-in of torque.
The servo arm has about 3/4" distance from the center of rotation of the servo out to the shift shaft. So, this translates into 55.4 ounces or ~3.46 lbs of force. This force is adequate, but it definitely does not give an immediate shift like a pneumatic cylinder does. If the arm was made longer, then the force of the servo arm would be less. I suggest not making your arm any longer.
As for shift time, the 0.19 seconds is the length of time it takes for that arm to swing 60 degrees. However, don't expect your gearbox to switch in exactly that amount of time. The first 0.1 seconds will remove the dog gear from where it was mated and then it will try to engage the other gear. Since the arm is pushing with only 3.4 lbs. of force, the engagement will not happen as quickly as it would if it was being pushed by 20 lbs from a 3/4" bore air cylinder. It may take longer (up to a full second or so) for that shifting dog gear to line up and slip into the mating dogs on the other gear.
Like any engineering decision, there are trade-offs here. For the benefit of giving up pneumatics, you are paying the price in having a lower force shifter that may take longer to engage and complete a shift.
Originally Posted by Justin M.
Looks great.
Yep, servo shifters have been utilized for a few years. We (team 45) had one in 1999 and then decided to publish a Servo Shifting Gearbox whitepaper in the summer of 2000.
Back then, the gearbox had to stop before the servo would shift. With the above design, the dog gear can just slam back and forth all day between the two gears, not caring what the motor speed is. Today's robot drivers have it pretty good.
Originally Posted by Billfred
Is anyone else getting a 404 for the Gifts page?
Yep... me too. grrr.
Andy B.
Unread 06-10-2006, 12:11
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
Rookie Year: 1999
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
Andy B.
Yeah, thats my fault. I'll get that fixed tonight.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 06-10-2006, 12:29
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
This is awesome.... The only reason we had pneumatics on our robot last year was for the shifting transmission. This will save those precious few pounds , especially when you are 25 pounds over weight like we were . We will definitely be grabbing a few of these in the near future.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 06-10-2006, 12:31
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
These look great, Andy.
One question - have you done any long term testing to see how the servo and the plastic components hold up during extended (and aggressive) use?
Say....running the transmission motors off a power supply for 8 hours while programming the servo to shift at 10 second intervals and seeing if everything is still in one piece and not melted/stripped/on fire the next morning? You know....fun testing like that.
8 hours operating time x (60 minutes per hour) x (60 seconds per minute) x (1 shift per 10 seconds) = 2880 shifts.
48 matches per season (worst case guess) * 20 shifts per match (again worst case guess) = 960 shifts.
I think 8 hours of continuous testing should cover it.
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 06-10-2006, 12:46
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Originally Posted by T. Hoffman
One question - have you done any long term testing to see how the servo and the plastic components hold up during extended use?
Don't worry, Trav--we're going to find out for ourselves. Just placed the order for a pair of 'em!!
Unread 06-10-2006, 16:01
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Finally! I love the idea of a servo shifter, and it's great that more people will get to see why I love them now! Say good by to your heavy pneumatics! Its a 10 Dollar upgrade that is money well spent (It's marked currently for $340)
Andy and Mark, what do you see as the disadvantages and advantages of the Servo shifter over the Gen. 2 Pneumatic Shifters?
Difficult question aside, great work! I can't wait to see them on a 2007 Water Game robot! (Are the gearboxes available waterproofed yet?)
Unread 06-10-2006, 17:08
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Your match estimate is pretty low if a team attends multiple off-season competitions.
25 played 50 matches through Regionals and Championship (but that's counting 7 Newton elim matches, and 5 Einstein matches), and attended PARC, Monty, and IRI (and still has Brunswick Eruption). They probably have played around 85-90+ matches. But they represent a very small portion of teams.
20 shifts per match is probably a little high though (116 would typically only shift around 4 or 5 times a match, at most, when we used a 2 speed). So, your estimate probably isn't that far off.
Being correct doesn't mean you don't have to explain yourself.
Unread 06-10-2006, 17:36
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
the new transmissions look great and look as if they'd be easier to use
Mecanum wheels+ (4) 2 speed transmissions..........
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #15   Spotlight this post!
Unread 11-10-2006, 23:40
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Andy B.
Andy,
We have a spare Gen 1 AM Shifter sitting on the shelf. Will the "servo shift upgrade kit" work with the gen 1 shifter? If so what is in the "upgrade kit" and when will they be available for ordering?
AndyMark Mecanums Joe_Widen Technical Discussion 10 05-09-2006 22:12
Andymark.biz Andy Baker Technical Discussion 119 01-05-2006 23:30
Calling All Ball-Lock Shifters team222badbrad General Forum 3 22-02-2006 22:13
mounting andymark wheels VEN Technical Discussion 10 04-02-2006 00:14
"Dog shifters" Ryan F. Technical Discussion 16 06-10-2004 10:07
