Go to Post Someone Photoshopping Heidi...............now there's a switch! - Jay H 237 [more]
Unread 08-10-2006, 22:14
D.Fahringer's Avatar
D.Fahringer D.Fahringer is offline
Engineering Tech
FRC #0122 (NASA Knights)
Rookie Year: 1997
D.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of light
pic: "Omni Grenade" Wheel
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
Team Role: Leadership
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
Re: pic: "Omni Grenade" Wheel
what could i use to make those?!?!?!?!
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 08-10-2006, 22:35
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
My God!
I'm making sure my team doesn't see this.
Very cool though. What are those really?
Unread 08-10-2006, 23:14
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
its an omni wheel with grenade shaped rollers. http://www.chiefdelphi.com/forums/sh...olding+rollers check this out its another thread on the same thing but a different picture.
PS can we get these two threads connected to prevent more confusion.
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 08-10-2006, 23:43
Engineering Tech
Rookie Year: 1997
Maybe the threads should be connected thanks!
GMKlenklen,
I would be glad to give you the files needed to make your own, but you might want to use them for making a machined roller out of rubber as opposed to our cast version. You can read about what I and my student Sam Elzarian did at NASA Langley's Technology Development and Integration Branch. Using Rapid Prototyping techniques we, with the help of Gary Wainwright also in TDIB made molds and a fixturing device to produce these wheels very quickly. I am not satisfied with the cure times for urethane plasics that are soft enough for traction. So, if I were going to do this again I would invest the time to machine rubber such as you would find in a trailer store that sells trailer rollers to roll boat hulls on. They already have a hole through and are reasonably priced.
I love the concept of an Omni Wheel but I have to say to be careful what you wish for, the extra mobility you recieve in your robot is unfortunately the extra mobility in your robot that an opposing robot takes advantage of when he pushes you! In 2002 our robot had omnis in front and we had 8 X 8 traction wheels in back but a very wide track distance, we were somewhat hard to push sideways only because of that wide stance mechanical advantage. That robot was five feet wide and 3 feet long!
We in 122 have been solid wheeled for two years, still very manuverable and great at pushing I might add.
Here is the link:
http://www.chiefdelphi.com/forums/sh...t=omni+grenade
Unread 10-10-2006, 08:56
NoSkaOnTheRadio's Avatar
NoSkaOnTheRadio NoSkaOnTheRadio is offline
Team 1757 Alumnus
AKA: James Carney
FRC #1757 (The Big Green)
Team Role: Mechanical
NoSkaOnTheRadio has a spectacular aura aboutNoSkaOnTheRadio has a spectacular aura about
Send a message via AIM to NoSkaOnTheRadio
this is by far the coolest looking omni i've ever seen. my team is considering a 6 wheel drive system this year, with two omnis as our front wheels. does anyone have any experience with that kind of system?
Unread 11-10-2006, 13:30
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
[quote=NoSkaOnTheRadio]this is by far the coolest looking omni i've ever seen. my team is considering a 6 wheel drive system this year, with two omnis as our front wheels. does anyone have any experience with that kind of system?[/QUOTE
Using two omni wheels on a 6 wheel drive could be complicated. If your robot has center wheels that are slightly lower than the other two (creating a teetering effect) the omni wheels would not have much of an effect on the handling of the robot, as they will only be on the ground about half the time. I definitely advise the omnis in the center or a four omni wheel with traction in the middle setup.
Schneidie
Unread 11-10-2006, 13:40
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
[quote=Schneidie]
We ran a six-wheeled drivetrain last season with no drop on the center wheel. The outer four wheels were all omniwheels and we had no trouble with this arrangement at all. Our machine was a dumper, so we were less at rish for being pushed sideways than a machine that needed to stay stationary to score.
Using just two omniwheels at one end of a six-wheel drive is another viable strategy that offers a bit more resistance to pushing than our arrangement, but correspondingly is more difficult to turn. However, you're effectively shortening your wheel base to ~18", so turning ought to be pretty easy in any case.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 11-10-2006, 16:05
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
lol those r awesome, we gotta get some on our bot next year!!
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
pic: "Vexie" aka "El Jorge" Kyle Love Extra Discussion 16 13-09-2005 22:32
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
pic: "Omni Grenade" Wheel D.Fahringer Extra Discussion 20 11-12-2004 13:02
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Will your team use a "5th Wheel"? Alex Cormier General Forum 15 25-01-2004 18:43
