Go to Post Engineering is all about trade offs. You can design yor system to do A, B or C easily. Combining A abd C or A and B or B and C requires some effort. Combining A, B and C should be near impossible. - Mike Betts [more]
Unread 11-10-2006, 11:31
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
EasyC-FRC - Arcade driving help
Our team is using EasyC-FRC (currently ver 2.7.0.2) this year. That's okay. Hey -- it's easy. But I need to get some starting point, and I always get hung up on something simple at the beginning. And if I don't know, how are my 20 programming kids going to know?
We have a 4-motor test robot, and we're going to use arcade (single joystick) driving. All of the examples in the Help file show the Tank mode, but no details on Arcade.
I've got the infinite While(1) loop okay; the joystick input okay using JoyX = AnalogOIInput(~~~) and JoyY = AnalogOIInput(~~~); and finally the OItoPWM(~~~) to send the info to the 4 motors. We do some magic calcs [1] with JoyX and JoyY to optimize our motors, etc, then send them to OItoPWM() -- how? Do we mix the X and Y somehow? How much goes to the left side motors and how much to the right side?
Or do we use the "Arcade - 4 motor" function block in the While loop instead, and be done with it?
Thanks for your help.
Roger.
[1] Magic calcs are currently to reduce the speed of the robot -- we have a small room to drive it.
Unread 11-10-2006, 12:40
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Talking Re: EasyC-FRC - Arcade driving help
First you need to be in L2 or PRO mode. On the toolbar at the top of the window you should see L1, L2, and PRO. Select the one you need.
Create a new competition project.
Open the Operator control function.
Under the RC Control section of the commands you should see a "Arcade - 4 Motor". Add this to the Operator control function.
The options for this command are fairly simple.
EDIT: "Advanced" code i attached is fairly simple.
Code:
int LeftDrive, RightDrive;
unsigned char JoyY, JoyX;
JoyX = GetOIAinput(1,1);
JoyY = GetOIAinput(1,2);
LeftDrive = Limit(JoyX - JoyY + 127);
RightDrive = Limit(JoyX + JoyY -127);
// the mixing code above  produce values out of the 0-255 range.
// we must limit the values or we will get overloads and weird things.
LeftDrive = Limit(LeftDrive,0,255);
RightDrive = Limit(RightDrive,0,255);
//Assign motor values.
//Left motors
SetPWM(1, LeftDrive);
SetPWM(2, LeftDrive);
//Right motors
SetPWM(3, RightDrive);
SetPWM(4, RightDrive);
The limit function used above.
Code:
int Limit (int input, int min, int max)
  if (input < min)
    input = min;
  if (input > max)
    input = max;
  return input;
I have attached a program for you to look at.
If you need more help PM or e-mail me.
EDIT: I have attached another file with custom arcade software. It may be easier to use your "Magic calcs" with this.
Eric Haskins KC9JVH
Unread 11-10-2006, 14:54
FRC #1153
Rookie Year: 1900
Thanks EHaskins -- to think it's as simple as:
LeftDrive = JoyX - JoyY + 127;
RightDrive = JoyX + JoyY - 127;
to mix the x and y axis numbers and get a motor speed.
Can't wait to get to that robot now!
Roger.
Unread 11-10-2006, 15:03
AKA: Eric Haskins
If you have any problems PM or e-mail me.
Eric Haskins KC9JVH
EasyC-Vex Rx/motor frustrations- please help! Steve0100 Programming 10 08-07-2006 02:18
help on easyC Loki1989 Programming 5 19-03-2006 08:42
Update for EasyC for FRC Available Kingofl337 Programming 0 07-03-2006 14:42
HELP!!!! EasyC Compiling Issues Wbrown0389 Programming 8 29-01-2006 09:18
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
