Go to Post Most teachers are not in it for the income, But they are definitely in it for the outcome. - Bob Steele [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 13-10-2006, 14:56
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Team Role: Coach
Rookie Year: 1996
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
[OCCRA]: Inspection
ALL teams are required to complete the Pre-Inspection form sent to your Adult Team leader. This inspection form is required at the time of inspection - COMPLETED!
If you have not seen this form ask your adult team leader.
Note: 1 error - the globe motor is an additional motor not replacing an existing motor in the kit.
WARNING!!! Each year teams come in overweight and are sawing of critical parts to get under the weight. Test your weight!!!!! Before the opening competition.
Hint: Driling holes saves very little weight and weakens your robot.
INSPECTION PROCESS: Fairness forms are turned in.
1. Teams weigh robot. 115 or less / 120 or less if using the compressor for Pneumatics.
2. Size Box: must fit in starting position 28 x 32 x 40 tall.
3. Electrical / Mechanical: A inspector will be checking the listed items on the pre-inspection form....and then some.
Points of many problems:
Sharp edges
Bare wires in connectors
Batteries NOT insulated
Batteries with no hold down strap.
BIG BIG BIG
Missing team numbers on all 4 sides and numbers to small.
Pneumatic relief valve missing
Missing cover on box
Non approved additional materials
Once you have passed inspection you will get a sticker placed on your robot. Please do not remove as this is used all season to record inspections on.
All inspections stop at the start of the competition. Any robot not inspected or passed by the start of the competition will not compete that night.
Mike Martus
Inspection process ttedrow Regional Competitions 14 08-03-2004 20:12
Inspection willross General Forum 4 25-02-2004 18:28
Robot Inspection Yan Wang Regional Competitions 1 20-02-2003 21:00
Inspection Sheet Mike Norton Rules/Strategy 3 12-02-2003 15:55
Inspection Mike Martus OCCRA 0 29-10-2001 21:45
