Go to Post Gracious Professionalism, it's hard to describe, but I sure know when I'm not living up to it. - rsisk [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 13-10-2006, 14:57
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Team Role: Coach
Rookie Year: 1996
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
[OCCRA]: Inspection 2006
ALL teams are required to complete the Pre-Inspection form sent to your Adult Team leader. This inspection form is required at the time of inspection - COMPLETED!
If you have not seen this form ask your adult team leader.
Note: 1 error - the globe motor is an additional motor not replacing an existing motor in the kit.
WARNING!!! Each year teams come in overweight and are sawing of critical parts to get under the weight. Test your weight!!!!! Before the opening competition.
Hint: Driling holes saves very little weight and weakens your robot.
INSPECTION PROCESS: Fairness forms are turned in.
1. Teams weigh robot. 115 or less / 120 or less if using the compressor for Pneumatics.
2. Size Box: must fit in starting position 28 x 32 x 40 tall.
3. Electrical / Mechanical: A inspector will be checking the listed items on the pre-inspection form....and then some.
Points of many problems:
Sharp edges
Bare wires in connectors
Batteries NOT insulated
Batteries with no hold down strap.
BIG BIG BIG
Missing team numbers on all 4 sides and numbers to small.
Pneumatic relief valve missing
Missing cover on box
Non approved additional materials
Once you have passed inspection you will get a sticker placed on your robot. Please do not remove as this is used all season to record inspections on.
All inspections stop at the start of the competition. Any robot not inspected or passed by the start of the competition will not compete that night.
Mike Martus
[OCCRA]: Inspection Mike Martus OCCRA Q&A 0 13-10-2006 14:56
[OCCRA]: OCCRA 2006 League Rules PDF ScottWalls OCCRA 4 20-09-2006 11:27
[OCCRA]: 2006 OCCRA Mobile Goal Drawings Brandon Martus OCCRA 7 18-09-2006 22:06
[OCCRA]: Official OCCRA 2006 game hint #1 Mike Martus OCCRA 10 08-09-2006 23:03
[OCCRA]: OCCRA Kit and additional parts 2006 Mike Martus OCCRA 3 12-12-2005 15:48
