2007 Robot Controller
Innovation first has been out of robot controllers since before the end of last season. Does anyone have any clues to what might be involved with the new controller?
Re: 2007 Robot Controller
If they are planning anything, its probably not major. I remember seeing mention somewhere of the RC being updated, but not redesigned.
You should search before you post. There have been many threads about this, but probably no big changes.
I heard that the new controller will have the capability of using USB joysticks, and the radio receiver may be internal.
James |
The current radios also arent that small. Unless they redesigned them i think it might be a little hard to get them on the RC board.
I wouldnt be suprised if they switched the programming port from DB-9 to a mini usb... i have a feeling that will probably be the only major design change...
I personally would enjoy seeing a radicle change but im not going to get my hopes up |
Anyway, I'm willing to predict a new controller available from IFI in the new future, whether or not it's for FIRST or not is a question. The only controller you can buy from IFI right now is the Mini Robot Controller, so who knows. They discontinued the Isaac Controller line, and they look remarkably similar to the FIRST controllers. Who knows, maybe there was some business reasoning for that. If there is a new system, I'd say it is going to be very close to the current Vex microcontroller |
#10
Right, many teams have the RC in the center of there bot. If the radio was internal you would have a small little radio that might not get reception because it is blocked. There is no reeal reason for the radio to be internal.
#11
First of all, the argument that the radio is big and won't fit is moot, as the radio is years old and has changed a bit, but it seems it has stayed the same shape to ensure modularity. If Cingular can incorporate and edge antenna into a card bus slot and little tiny rc cars can run on 900mhz, the receiver can fit in the RC as it stands. For benefits on the consumer side, it eliminates a serial cable and another electronics box. We can all use that extra weight. Its also just a more elegant solution than having cables running all over the place. On the manufacturing side, it eliminates another PCB to print, and another box to mold. You can sell a cheaper product for the same price. More money in your pocket. |
#13
Ohh yeah That would be sweet seeing as that most laptops don't have serial ports anymore, and since when did you see a programmer working on a desktop in the pits? |
#14
| Robot Controller | NotaNerd | Control System | 6 | 04-11-2004 16:53 |
| 2004 Robot Controller | CNCBoy461 | Electrical | 18 | 02-12-2003 16:36 |
| Robot Controller | Josh Hambright | Electrical | 2 | 23-01-2003 13:36 |
| Robot Controller | srjjs | Rules/Strategy | 4 | 08-01-2003 19:08 |
| Robot Controller | archiver | 2000 | 3 | 23-06-2002 22:54 |
